Rodney64
Just had some new side panels made up.
Perhaps u need to Korpinkorpin said:I have honestly not read anybody elese posts because i am a narcissis but have changed the title of my reply....
i REALIZE THIS list is old and I took LOTS of time to reply,but I never did say thank you for letting me know HPC does not really match the brakes to performance of bicycle.......hmmm what kinda bikes are shown on the stealth bomber website (DOUBLE cooling holes MULTI pot)? I think I NEED those!!!!!full-throttle said:So-sokorpin said:.are those brakes in photo good or just so-so brakes?
Have a read on bikeradar:
- Power ratings (in ascending order of power)
Brake model Power (Nm) Weight (g)
Ashima PCB 64 328
Tektro Auriga Pro 77 491
TRP Dash 85 407
TRP Dash Carbon 85 393
Gusset Chute 89 469
Hayes Prime Pro 90 501
Avid XX WC 90 356
Magura MT8 90 339
Quad QHD-7.1 Nano Light 92 422
Quad Rapide 97 475
Hope Tech Evo X2 97 463
Quad QHD-7 Nano 97 463
Avid Elixir 9 99 397
Avid Elixir 7 99 395
Avid Elixir 1 100 471
Avid Elixir 3 100 442
Avid Code R 103 429
Magura MT2 103 428
Magura MT6 103 337
Shimano Deore M596 104 490
Formula R1 Racing 104 334
Shimano Saint 105 529
Shimano XT M785 107 466
Formula RX 107 398
Formula R1 107 355
Shimano XTR Race M985 110 388
Hope X2 Race Evo 110 377
Shimano SLX M666 111 485
Shimano XTR Trail M988 112 407
Hope Race Evo M4 115 496
Hope Tech Evo V2 120 524
Formula The One 121 393
Formula RO 124 418
was kinda wondering if those panels get hot in sublight?Rodney64 said:Just had some new side panels made up.![]()
Nice Rodney what are your plans for fitting 24 fet in frame?Rodney64 said:New controller. Blown 12 fet beside it
dimpirate said:Nice Rodney what are your plans for fitting 24 fet in frame?Rodney64 said:New controller. Blown 12 fet beside it
Just got 24 fet methods controller had to buy special packs for room left over.
By the way love the new side panels
Rodney64 said:dimpirate said:Nice Rodney what are your plans for fitting 24 fet in frame?Rodney64 said:New controller. Blown 12 fet beside it
Ill try and mount the controller inside but it will need to be on its side. Yes Dimpirate the side panels do look good. Hope to have the bike back together on Friday and will post some pics after I've installed the controller.
What do you mean when you said you had to buy special packs for room left over. I'm thinking battery.
36 fet. Yes Zombies controllerdimpirate said:
From your battery pack pictures it looks like controller might fit in, it'll be close, you might have to do a little pack splitting hopefully not!
Reason i had to get special packs is because Methods controllers top voltage is 100V and that's how much it's gonna get... So I can only use 4S 6S and 8S lipo combos. 5S is actually most ideal in measurements for phasor frame, just forces me to loose V to not hit controller limit.
6S, like I believe you realized when first building is usually a bit to wide for frame so that fumbled my plans up a bit.
Anyways let me shorten thsis up
zippy compact 8S 5.8Ah packs are the best option of very few to reach 24S4P goal. Packs should be on there way :lol: placement will be like in pic each paper is 2 packs side by side. 12 total ( better than 16) and 3.2 Ah more than I originally planned for. Cool!
Is that 24 or 36 fet?
Zombies?
Are you going to be increasing voltage?
Cromotor to?![]()
Rix said:For the KISS factor, mounting the controller on the outside of the frame where the air can cool it seems ideal. I know that Kepler has had phenominal results with internally mounting his controllers on the inside of his Fighter and Dh Paule's Bomber, but if I recall correctly, he had to remove the controller cases for the install so he could use the frame as a heat sink. Is there a warranty concern? Of course, the folks on this forum for the most part are concerned about performance and will do mods that would void a warranty if it means more acceleration and speed. I guess my point is moot. This is the beuty of the Phasor, having the freedom of choices to do whatever the builder wants.
Rick
Methods assured me I wouldn't even need to heat sink to frame, that cromotor would melt before controller gets started warming up .
I'd Imagine Rodney's controller doesn't need to heat sink either. Right?
Rix said:Methods assured me I wouldn't even need to heat sink to frame, that cromotor would melt before controller gets started warming up .
Dimpirate, you misunderstood me, if you did heat sink the controller to the frame, you have to remove the controller case so the controller is in direct contact with the frame. With the controller in its case, the case is the "heat sink" instead of the frame so you don't have to worry about heatsinking. I appologize for the confusion![]()
Rick
just wondering if the pcb in the heat sink case would fit in the frame on its own, is it 95mm inside dimension? it may be just enough, the pcb may be able to just fit. but if its easy enough for you to mount it all in there with the case on you might as well. hope its working out well in any case, peacedimpirate said:These controllers are wider than frame so outside placement is awkward, ugly.
Methods assured me I wouldn't even need to heat sink to frame, that cromotor would melt before controller gets started warming up :lol: .
