remf said:wugambino said:Question
I use "mechanical sympathy" when climbing, and always pedal my ass off(usually). Some of the hills are STEEP, and even the "kings of the mountain" have to go 1mph in granny gear to make it up barely. I have checked my motor and controller temps at the top and everything is still cool/barely warm. I have even checked it a couple minutes after to see if it heat soaked and always cool.
Every time I ride anywhere, I always use max amps(amax=65.7a'ish), and I have glimpsed 2600watts
-Am I being gentle, or is the climb duration not long enough for component heating? (Appx. 3minutes hard climbing at 3/4 throttle with a 20second WOT burst at the pinnacle. )
I'd say the climb duration isn't long enough. According to http://ebikes.ca/simulator, depending on your weight, it would take just over 4 minutes to overheat a 3540 climbing a monster 20% average gradient.
Thanks for the chart. I just wanted to be sure I was being "safe".
I have a newer Fighter with the 4080 motor... Is that listed as the 408 in ecalc chart?
There is a big difference between 24" and 26" wheel... but does how does it actually calculate "roll-out". Do you think the diff is real since we use 25 3/4" , 24" tires/wheels?.
