54xx series are monsters. They are like extinct dinosaurs.
When I used a cromotor it was a lot better in every way during a short test. Lighter, better acceleration more efficient and less heat building up.
Looks like high turn count motor is worse when you want to hot rod:
What I have taken from the "myth" conversations is this:
A higher-turn (Lower Kv) motor like the MXUS 5T has the ability to provide the same torque as the 4T with ~20% less phase amps needed at a given voltage. The only advantage to this that I can see is the ability to run smaller phase wires to the motor. (The stock phase wires from MXUS are 2.5mm2 or ~13 AWG, so not very big.)
The lower Kv motor will also reach peak efficiency at a lower speed (given the same voltage) than the higher Kv motor. - So if you don't want to ride fast all the time, the 5T is perfectly acceptable.
What you DON"T want to do is run the same high Phase Current that you might with a 4T motor as you would with a 5T motor, since you are more likely to toast the windings in the 5T motor.
I think what John in CR is saying is that if you want to Hot-Rod a motor, it's better to choose a lower-turn (Higher Kv) motor, since it can handle more phase amps than a lower Kv motor, or conversely, you can get the same performance with a lower voltage and higher phase current with a high Kv motor as opposed to the low Kv motor.
http://endless-sphere.com/forums/viewtopic.php?f=2&t=63142&start=675#p978572
