1abv said:I hope you are all happy!!!
I've ordered a KLS-S 72V, 200A..... more to come.
Theodore Voltaire said:1abv said:I hope you are all happy!!!
Is this the one? KLS7218S
https://kellycontroller.com/wp-content/uploads/kls-s/KellyKLS-SUserManualV1.10.pdf
1abv said:Hey tv can I ask your onyx bud what throttle they are using?
Thx!
Allex said:Got a Kelly KLS7218S installed
Gives me over 100A battery amps and over 200A phase amps to motor with a 35mm wide stator. 5403 on bombers are 43mm (or 42mm) Wider stator gives you more torque.
https://www.qsmotor.com/product/kelly-controller-kls7218s/
My old bomber got over 400A phase amps to motor, but you have to have a temp sensor installed to monitor the temp.
If you can get a nucular 12F or 24f - do it! it is a fantastic piece of hardware with great support. Otherwise, kelly is fine But it is a bit of a hassle to connect it to the CA and you need to program it using a PC, did not get it to work with their phone app.
Allex said:Shunt will work fine. Just a bit bulky because of the black base that is made for mounting it onto chassis.
diode, contactor, precharge and fuse, non of these are used in the stealth bikes, so you can skip them.
But a fuse on the positive is a nice to have feature, safety wise.
Listen to these three video guides on kelly setup
https://www.youtube.com/watch?v=A_si4IfU5so
