It just requires glued cells and minimal padding....but appears like it should be totally achievable.
I'm sure others have done this before, but I only just realised!
Cheers
I can conclusively report the performance of the 50s cells is impressive. My new homemade 35ah pack is way better that my previous Chinese factory 35ah pack. Not only does it have about half the sag, it also has a lot better range, even though on paper both battery's should be about the same.
Yeah, there's something to be said for quality builds. You can loose a lot of capacity to lack of series nickel/copper links, poor main discharge terminations, crappy/cheap BMS, underspec'd connectors and/or non-genuine cells. I see a mix of all these things in almost all China made packs.
Cheers
Cheers
Knowing what I know now, I'll probably never buy another factory battery. That being said, I just bought one of these in 72v that's made from 50e cells, but only because I want to see how they made it so I can build another one using my BGX battery shell. battery shell.JPG
FastAce forks
I have been trying to get these forks working as best they can.
The ride was pretty harsh basically over all forms of bumps but particularly noticeable road riding.
I've watched lots of tutorials on these and read whatever I can find.
Stripped them down numerous times diving a bit deeper each time.
In summary the "sticktion" was very bad. High speed damping not great but the low speed damping ok. Heavy.
Pros are they seem to be strong and durable, they look cool (without all the bumf I've strapped on)
Sticktion greatly reduced by pulling apart the legs and greasing the very tight and heavy oil and dust seals. Replacing fluid with a known brand (right side as left side is empty, spring only, though I put a splash in for lubrication)
Also forks rest at slightly different lengths so spending time getting them sitting aligned makes some improvement
(Side note spending time getting the brake caliper aligned and axle sitting nice made a huge improvement on brake and wheel bearing drag)
All that improved sticktion a lot. But still too much sticktion remains.
SKF green seals can be bought which I haven't and could possibly reduce the remaining annoying sticky sticky.
I haven't touched the shims. The high speed damping.
To get to them requires the fork foot removed and I'm not up for that yet. That said from what I can tell the stack is small anyway and very limiting even if you want to replace shims.
The springs seem ok for general purpose both front and rear but a bit saggy. Front could do with some preload but that's anything but easy to do. Rear shock I think is generally ok all round. Not great but ok.
These forks are used on Surron and Talia and all the YouTube clips referred to them. Nothing on a Stealth.
Boom. My function over form mirror extension.
Soon to be trying a thumb throttle
It's been awhile but just wanted to post up that I found B-52 #273 at a yard sale in SF two weeks ago. I was told by the sister of the original owner that he (Steven), really loved that bike but had passed away unfortunately while at an amusement park. I promised I would honor her brothers memory and return the bike to running condition.
This being the third B-52 I've purchased used, I knew it was probably worse than it appeared and boy was I right. I have become a bit of a Stealth parts hoarder so I promised myself that this was a good way of getting rid of (or consolidating) all my spare parts I have accumulated over the years. 😉 I know the Suron stuff is all the rage right now with wheelie kids, but I still prefer the silence, performance the ability to ghost pedal that I get with a Bomber. Not to mention, actual plated Stealth Bombers are some of the rarest mass produced ebikes in existence.
-The battery was actually so swollen it took multiple grown men to get it removed from the frame and when placed on the charger it immediately caused a "thermal event" in the driveway so into the dunk tank the pack went, for a week. I happened to have 100 Molicel P45B 21700 (from a group buy) and an ANT BMS laying around so I built a 21s X 5P pack.
-The controller was some kind of knock off Sabvaton that never actually worked, so I ripped it out (along with the cycle analyst) threw on an (OG Pre Covid) Nucular 12f controller. What a powerful little controller that's not much bigger than a pack of cigarettes. I had to do 5 years of Firmware updates on the controller and the screen all via Micro USB 😭
-Even just pedaling the bike felt really out of balance as was crazy amounts of rear axle play due to bad bearings and both inter tubes had Fix a Flat, which is messy stuff. Replaced bearings with spare SK 6005 and 6004 bearings that I had laying around. Also changed the stater with a spare I had as one hall sensor wasn't registering at all and the other two where showing 0-2v (should be 5vdc), when a magnet was passed over them. Also found an intermittent short on one of the phase wires where somebody had done a shoddy repair. Halls will be here in a week but I wanted to ride so in went the spare stator in a Moto wheel and extend soldiered on the appropriate XT150 and crimped on connections to match the Nucular 12f.
-Swapped in a set of 3" riser bars / changed the grips and put new brake pads on front and back.
-The Rock Shocks are pretty much blown out and need to be replaced, my other B-52 has a set of $1500 Fox 40 air shocks on it but I just cant bring myself to spend more on a pair of shocks than have in the entire bike. Maybe I'll ask for them for Christmas?
After nights of "tuning rides" where sometimes I had to push or peddle home, I decided to throw a full charge on the new battery and crank up the phase amps and the Flux weakening to stretch her legs a bit. Knowing these are older and not super efficient Crystalyte hubs I wanted to see how much heat I'd be generating (in the motor, battery and controller) over a few miles of consistent 70-100% throttle and regen. I was able to hit 62 mph on the GPS, tucked and the motor was pretty warm to the touch the controller was far cooler than the Sabvaton on my other Bomber that is 2-3x the size of the 12f.
Thanks for posting this and waking up the thread. You really made that a very sweet and restored bike. Look forward to seeing more of it the pages to come.
Oh darn, it was you that ended up with it! Haha I was driving out to go pick it up when the guy texted me back to let me know it was already sold. Glad at least someone on here got the good deal ;)
It hasn't happened to me but I've read that the axle 14mm fine thread can be damaged or stripped.
Looking for a nut with more thread I found a standard nut also a conelock nut.
The original nylock has about 5 threads.
The standard about 7
The conelock about 8
Wanting to use the conelock without the locking as it's too severe. And not having a 14mm fine tap, I used a regular 10mm tap which has the right pitch as a sort of thread file to cut away the punched locking threads. There's very little that needs to be removed.
I'm assuming it will work and be less likely to strip. 🤞
Who knows if I would have had a problem anyway 🤷🏻‍♂️
Couple of simple ones.
Placed some washers there (shims would be better) to get more there.
Gen 2 optional rear guard has a big space. Chop chop an empty AdBlue container and voila.
Cheers
I have done several bomber batteries, the 20x10p fits perfectly and 21S9P also fits very well. I personally ride a 21S9P for years without any problem, it measures about 33cm x 11,5cm.
Winter and Summer wheels
24" #5555 off-road tyre
Evidently a Gen 1 Bomber motor.
Turns out it would be on a 26" rim ~55kph on 14s which happens to be ~55mph on 20s and that happens to be ~80kph which coincidentally corresponds to the #5580 on the Crystalyte website.
The street wheel is the original Gen 2 fighter motor and it's in a 27.5" rim.
Apparently a #5565 which happens to be ~65kph on 14s which is ~65mph on 20s which is also ~100kph which coincidentally corresponds to the #55100 on the Crystalyte site.
There is no #5555 or #5565 on the Crystalyte site.
Bumped the shunts.
Unable to measure actual at the moment so just doing the maths with the info I have.
If it was the claimed 60A it is now 85A worked out using the error in the Wh reading.
Overshot a bit with the mod😬
I can only use the increase for short bursts to get out of, or get into 😁, tricky situations as the battery isn't up for it.
All in all pretty happy with the large increase in tractable torque off-road and the street wheel is more fun after the shunt mod alone.
Yep there are compromises and costs.
2 bikes in 1😎
Bumped the shunts.
2 bikes in 1😎
Looks good, definitely a great warranty voiding mod CD suggested. How does that pair up with the 5555?
Hy I have a Stealth F-37 and have a message on the display "Power too hot" after riding about an hour. Can anyone tell me what this means? Controller and motor have minimal temp on the display and are not warm.
It seems great. It's warm and dry here now and the bush is not very appealing so I haven't given it a real shake down. Only some grassy parks in the suburbs.
There's now next to no lunge forward on take off. Just turns the rear tyre slowly and controllable. I can walk next to the bike and use throttle which will be good in the tricky stuff.
The 5555 in a 24" rim more like driving a forklift than the 5565 in a 27.5". More ability to crawl.
5565 in 27.5" is great on the street. However I've got a 24" Hookworm on the way so I can ride some distance onroad because winter is just too far away to wait. That'll be interesting.
The shunt mod took the 60A controller to 85A. Most definitely noticeable and all round good.
A 4400W fighter is 🙂
However it probably hurts the standard battery's feelings and heat comes to everything quickly.
So I only use "Competition mode" sparingly. Mostly riding around in "Speed" mode which I guess is around 65%
I have a gen 1 that I purchased 3 years ago in March. I have reset the DC-1 but I will get back to you with the details. I have activated the soft start function and there was no problems since. It could have been the BMS overheating and giving less power. I hope it is not the battery since they are so expensive.
If you have a Gen1 purchased 3 years ago, its actually way older than 3 years. Depending on who you ask, the original Gen 1 built in 2008 had huge frames and designed for LIFPO4 Headway Cells. Then around the end of 2010 early 2011, the frame sizes were decreased and Stealth Switch over to a LIPO4 24S pouch cell. That model has been referred to as 1st gen but its really the 2nd gen though. So whether you have that model, or the actual 1stt Gen headway cell model. If you are running the original battery, you need a new one.
24" Hookworm
UFO 5555
Shunt modded 60A controller bumped to 85A
My brief🤣 review
This was bought for more torque for off-road exploring in winter and significantly more torque it has👍
Only tested onroad so far.
Onroad. First thing is I need to run it in Competition mode as it just doesn't have the speed or power in Speed mode. Speed mode (No 2) is what I use with the 27.5" UFO 5565 onroad.
My guess is throttle input is connected/linked to duty cycle output. (What I believe people in the ebike scene call Speed control) and whatever the presets are for Speed No1 & No2 they're pretty useless on this wheel.
Competition mode the power is great, on tap without any fuss. Still nowhere near lifting the front wheel. Max speed still ok onroad at 60kph as apposed to 80kph on the other wheel.
Riding the same distance this 24" uses more power. Not through inefficiency but just using the power more. Also the peddling (which I like to do) is a much lower speed so not much peddling happening to assist. Will be good off-road though.
Peddle clearance not great standard is annoyingly but predictably worse.
I kinda like the geometry change of slacker fork angle and seat more rearward in relation to peddles.
Lower seat height is kind to my short legs.
Pretty much no lunge forward on standstill start.
So I think this hits what I was aiming for off-road pretty much spot on.😁
Nice onroad and I was going to keep it on for a while for the novelty, but not peddling has my hips, bum, legs getting uncomfortable and stiff.
So,,,, the 27.5" UFO 5565 is back on and will likely stay on till it starts raining
Well as some of you probably guessed based on the battery I was talking about building above, I do have a Bomber, however I bought it a few years back with a dead battery from previous owner on ES with the intent to fix it up and use, but instead never rode it and have only now gotten around to building the new battery for it.
I'm unlikely to get good use out of it all things considered so instead am selling before I degrade it's monster 50AH battery.
Details in the thread below:
If anyone in Australia would like to buy the battery from me, I'm open to offers. Considering it is 3600Wh, offers should be in-line with that.
Cheers
This machine has the QS 273, a 21x1.6 rim and MC tire on the rear, and judging by the huge new torque arms, this thing moves out quick.B52b.jpg
Stealth has listed the new Overlander on IndieGogo
I was hopeful to get back on a Stealth in 2023... then again in 2024... maybe 2025 is the year of the Overlander?
Seems they've got 3 different versions of it now (or soon) - there's a video with the 3 variants on their homepage:
https://video.wixstatic.com/video/c8e153_eb194ab3fa7c4ee8aabf9ef99d99afc7/1080p/mp4/file.mp4
But no mention of them on the site anywhere else.
Old variants:
- Overlander R (some of these have been delivered - supposedly all who backed)
- Overlander (none of these have been delivered as far as I am aware)
New(er) variants to replace the old ones?
- XTRM-bike - full suspension
- XBIKE-G - gravel version (front suspension)
- XBIKE-T - city bike - rack and mud guards, flat bars
The T bike seems to have front suspension in some of the shots (the paint demo photos) and in the riding demo none at all.
I’ve just bought bomber #875 I’m told it’s a 2021 model, I’m not sure about this? Also is it possible to get a battery off the shelf rather than build one?
I don't know the bike you mention - if that has a proprietary battery form, I don't know. Sources like Bosch include codes so their controllers decline to use any battery not made by Bosch.
But otherwise, a volt is a volt. Depending on what you are faced with, it is probably possible to just hook up wires if there are no booby-traps such as the above. There are details to consider.
