Theodore Voltaire
1 GW
I made this adapter for power take off on my sons B52.
Cozen89 said:Haha you do sound a little like an infomercial but with the specs you mentioned, I don’t blame you. No converter needed, bright, and affordable? Can’t really ask for more. I’m not the best at electrical, how do you plan to wire it up? Thanks!litespeed said:The one I have is actually amazing and relatively cheap. It has a daylight mode, low and high beams and works up to 60 volts. I can not for the life of me figure out why everyone doesn’t have one??? Not a cheap piece of crap either. Very well made, lighting is great, daytime-low-high function works well and the mount is very, very solid. This light is very, very bright! I’m installing blinkers and tail/stop light and wanted a low/high light to complete the package. I wasn’t ready to fork over the $400+ cash for the best available Supernova M99 pro……this at 1/4 of the price is the next best thing. I do have the Supernova tail light though…..very well made unit. https://ebikes.ca/spl-01-1900-lumen-ebike-light.html And to boot it’s from our sponsor Justin/ebikes.ca so what a great way to get one of the most advanced lights available for a great price while supporting this great forum you found out about this on!!!
I know….I sound like an info-mercial but it’s a great ebike find.
Tom
P.s. don’t notice the wires……it’s a work in progress & not hooked up.
Tom
1abv said:Tom,
What are you using for a fuse/ breaker and are you using a precharger?
Thanks!
Alex
I’m in line for a 24f nuke and wanted to see what others were doing.
Mine has the brake light also.Cozen89 said:Does your super nova tail light have a working brake light too? Or just a light up tail light?litespeed said:The one I have is actually amazing and relatively cheap. It has a daylight mode, low and high beams and works up to 60 volts. I can not for the life of me figure out why everyone doesn’t have one??? Not a cheap piece of crap either. Very well made, lighting is great, daytime-low-high function works well and the mount is very, very solid. This light is very, very bright! I’m installing blinkers and tail/stop light and wanted a low/high light to complete the package. I wasn’t ready to fork over the $400+ cash for the best available Supernova M99 pro……this at 1/4 of the price is the next best thing. I do have the Supernova tail light though…..very well made unit. https://ebikes.ca/spl-01-1900-lumen-ebike-light.html And to boot it’s from our sponsor Justin/ebikes.ca so what a great way to get one of the most advanced lights available for a great price while supporting this great forum you found out about this on!!!
Tom
1abv,1abv said:Litespeed,
If you don't mind a few more details?
-Where did you get your breaker from and what is it?
-what anti spark connections are you using Powerpoles?
-what gauge wires are you using for your battery?
Thanks for the info in advance! I'm trying to determine my build but im a little in the dark about some of this any help would be great!
Cozen89 said:When converting my mt5 brake levers to mt5e to control a brake light, am I looking for nominally open or nominally closed levers? Thanks!
litespeed said:1abv,1abv said:Litespeed,
I don’t remember exactly where I bought mine but this is very similar, https://www.solaris-shop.com/midnite-solar-mnedc60-60a-circuit-breaker/
I use the offshore electric 8mm ones because the 10mm were not made when I built my battery. They are huge and are good to 200 amps…….I run mine higher! https://www.offshoreelectrics.com/proddetail.php?prod=ose-qs8-anti
I have 8 gauge battery cables because they were out at my supplier of 6 gauge.
8 gauge is ok up to 225 amps and 6 gauge up to 275 in bursts…..not continuous! If I hold full throttle (17 kw) for more than 7 seconds I’m at 65 mph or higher.
I’ll help with anything I can.
Tom
1abv said:That calc is pretty interesting. I suppose I would have to do the math on what the max battery output would be and not on the phase side. I've run into a similar situation where no one is able to tell me what size breaker to use and what its based off of. like cable size, battery output... time of day.... what I had for lunch that day...
Made it up this monster.....then took a nice long motor cool down break..
litespeed said:I’m using a D/C breaker and I would assume 99% of the guys running them are also.
Here is a big one…… https://www.altestore.com/store/enclosures-electrical-safety/overcurrent-devices-fuses-breakers/panel-mount-circuit-breakers/midnite-solar-250amp-125vdc-panel-mount-breaker-p9924/
Tom
