bigbore said:Hello, I joined the Bomber chassis broken club with my #301.![]()
I'm going to repair it at a local moto/auto shop with a TIG welding machine.
I need to add a little piece of sheet metal, can you tell me which metal I should use to do this repair job?
Regards.
Rix said:bigbore said:Hello, I joined the Bomber chassis broken club with my #301.![]()
Regards.
Its going to be aircraft grade chromoly, let me see if I can get the specific numerical matrix of the material.
Yes, apparently you reached out to Stealth about this. Use ER70S2 or ER80 wire to weld.bigbore said:Rix said:bigbore said:Hello, I joined the Bomber chassis broken club with my #301.![]()
Regards.
Yes, you'r right it's AISI 4130 and I ordered one piece of sheet metal from an aircraft supplier shop on line
Theodore Voltaire said:I fabricated these two crude adapters that allow me to connect the eBike diagnostic tool to either the male or female side of a hall sensor plug. The tool worked perfectly, and indecated the motor windings, and hall sensors are good.
Theodore Voltaire said:Sooo, it looks like I blew the controller. I have to confess there might have been a little booze involved. It was around 9 pm and about 100 degrees outside when my son and I left our favorite imbibing house, the Beer Hole. A couple of 16 oz glasses of 10.0 really gets your motor going.![]()
ycxtdxy said:Hi inner dropout size is 170mm outer measures 190mm. Can I fit a 7 speed freewheel or more in there? I already have a fat 26*4 rim in there
1abv said:Yup thats the one I got. I'm working in installing it right now actually.
Rix said:Theodore Voltaire said:Sooo, it looks like I blew the controller. I have to confess there might have been a little booze involved. It was around 9 pm and about 100 degrees outside when my son and I left our favorite imbibing house, the Beer Hole. A couple of 16 oz glasses of 10.0 really gets your motor going.![]()
Now thats what I call a good time. If we lived closer, we would be great friends.
Theodore Voltaire said:ycxtdxy said:Hi inner dropout size is 170mm outer measures 190mm. Can I fit a 7 speed freewheel or more in there? I already have a fat 26*4 rim in there
The dropout width doesn't matter. Your motor determines what size freewheel you can use.
ycxtdxy said:My motor is a 2000W from china , which speed freewheel fits in there?
1abv said:Computer??!!! That’s way too far in the future for me!
Actually I’m not sure yet. I’m getting the wiring to get it moving I know there is CA that will work but haven’t really looked into others. Maybe what onyx uses? Let me know if you find anything
