Theodore Voltaire said:This probably sounds stupid, but even though I've ridden all my life, it's new being able to pedal and throttle at the same time.
What I've learned is to let the throttle decide what gear to be in, not how hard the pedaling is. Trying to drop down a few gears to get better pedal leverage, just wastes time.
Longshot said:Theodore Voltaire said:This probably sounds stupid, but even though I've ridden all my life, it's new being able to pedal and throttle at the same time.
I never shift. its always in top gear. I am thinking about removing all the shifting cables for a cleaner look.
peters said:Does anyone know how much is the motor torque of a new Bomber? (max. continuous and start-up torque if they are different, with its own controller)
Thanks!
Theodore Voltaire said:peters said:Does anyone know how much is the motor torque of a new Bomber? (max. continuous and start-up torque if they are different, with its own controller)
Thanks!
It feels like a lot. I'm guessing between 6 and 10 ft lb
peters said:Theodore Voltaire said:peters said:Does anyone know how much is the motor torque of a new Bomber? (max. continuous and start-up torque if they are different, with its own controller)
Thanks!
hmm, 10 ft-lb is 13.55Nm, but it should be around 100Nm (or more or a bit less), as it is a hub motor...
bigbore said:Today I rode 92 km and now I'm quite tired, even if the pedal assisted is not very strenuous it seems like a great exercise to keep fit![]()
A good news is that mt PAS system is working, I will post soon the final details of the circuit and a video where you can see how the PAS works
This Bomber e-bike is amazingToday I was in some trails 15 Km away from the house, which I had never seen before.
Thanks!
00Tj said:This may sound like a dumb question but what way does the Suntour pedal's come off? Do I screw the hex clockwise or anti? And does it differ from left to right??
00Tj said:So which is it???
Left=Anti clockwise and right=clockwise?
Allex said:I guess you dont want to read through 400pages, so:
Bomber with PAS
http://endless-sphere.com/forums/viewtopic.php?f=6&t=62650&start=150#p1029494
Allex said:The bikes works just fine with throttle only, just apply a small amount of throttle if you actually want to pump you muscles, you get used to it, it took a day for me.
But of course, ultimatley it would be nice to have a system similar to what eRockit have.
For me, CS is worthless you can do the same with throttle. But what is interesting is TS.
