Well... here is the update..
I was able to finally wire up the rest of the Hall & Temp wires in today and test everything out.
COMPLETED - The New 10 awg Phase wires and XT150 connectors installed
COMPLETED - Strap all of the wires down to the hub, heat shrink and revarnish everything
COMPLETED - Drill & Tap filler holes in hub cover
PENDING - Find and order Ferro Fluid
PENDING DELIVERY - HubSinks and Install ETA 9/20
COMPLETED - Put everything back together, say a little prayer and test
GOOD NEWS - Just about everything worked..!! I'll explain in a second
- Everything powered up fine and a little twist of throttle and all was good..VERY HAPPY..!!
- I didn't take it for a test drive yet, however, there was no delay, no hesitation, and the wheel spun strong.
ISSUE - After I connected everything back up, I turn the key on and everything was fine. the DC1 prompted me for my pass-code and ONLY the Up arrow and Menu button would work. The DOWN button and OK button would not. I had to hit the up arrow to each of the codes and wait 30 seconds or so for it to go to the next code so I can hit the number.
So I took the DC1 back out and took it apart to inspect
- I can feel a good "depress" of ALL of the buttons. I can hear & feel them click fine
- I sprayed a little T9 lubricant on each of the buttons
- I dont see or smell anything burnt on the circuit board
- The ribbon cable was all the way in and also in great shape
- The connector pins are also all tight and fully in the connector
- I reseated the thing about 10 times
- When you depress the Up arrow or the Menu button, you hear an audible beep, however, when you depress the Down Arrow or OK button you can "Feel" the button being depressed, but you dont hear anything
Any idea's...?
