Hey everyone. SB #123 owner here.
I would like to start by saying that, overall, the service provided by Stealth has been far from exemplary. Whilst I appreciate this is not an official stealth forum, I'm just letting you know these frustrations are simply vented generally - not directed at anyone here.
Firstly, the bike arrives with a horrendously-dented side panel, and the rear wheel mounted the wrong way around. It also arrives with a damaged charging port, which we have to bend back into shape using leverage. It takes them over a month to send a replacement side panel, leaving me without a bike for a long time. Thankfully, they do replace the part. I then have a month or so where all sorts of niggles crop up: First, the motor conks out unexpectedly during rides. Then I discover the Torque specifications provided in the manual are completely wrong; the suggested 45 Nm for the wheel nuts is too low, resulting in loosened wheel nuts after short rides. Tightening to 48-Nm eliminates the problem. The Torque values for the front wheel and crank arms vastly exceed manufacturer recommendations; I'm only able to loosen the crank down to manufacturer values by using a huge, hollow iron pole for leverage. It's a wonder it didn't strip the thread, doing the cranks up to 60 Nm.
Various other niggles occurred. Among them, one of the phase connectors 'melted' and seized up, prompting us to buy a soldiering iron and shrink connector to repair. The solder failed on the same connector, prompting the wire to come loose.
I don't know about you guys, but when one pays over 8 grand for a bike they kind of expect more. I recently sent a detailed correspondence to the workshop team at Stealth basically stating that a new concern had developed with the bike; basically, power output is limited. The gist of it is that I've rode the bike just fine with no problems, I put it into storage for a week, took it out, charged it for good measure, and all of a sudden two things happen: 1) The motor/throttle randomly cuts out for brief intervals, typically only when under load, and 2) the power seems to max out at around 3,200W, where before it could peak going uphill at nearly 4,900W! This is a recent development; the bike has been fine until this started happening. The only time the bike performs perfectly is the first ride directly after a BMS reset. Then it runs fine. Put it on charge as normal and the very next ride starts experiencing the power limitation issues all over again.
We did a better job soldiering the loose connector than Stealth did so we do not believe a loose connector to be the culprit. Also, we do not believe the battery to be at fault as it's stored within recommended temperatures, well-looked after, and unplugged + conditionally charged if unused for long periods. I believe I have narrowed down the CA as the culprit, because disabling it returns full power to the bike as normal. For whatever reason, the CA has started throttling the bike's performance. NOTE: the CA settings have remained unchanged since the day Stealth set them up in the factory.
Anyhoo, to get back to the point, I sent this very detailed email to stealth explaining all this about the power cutting out, and what measures I've taken. I even went as far as to tell them what settings the bike came with on the CA. I then told them I'd tried using the CA settings an Endless-Sphere user provided and the problem went away. I finally asked the guy at Stealth if he could provide a list of CA V3 specifications/stealth factory settings; surely they must read these off a big sheet or something at the workshop when setting up new bikes?
All I got is a tiny little reply saying I should return the CA to Stealth's factory settings, and disconnect it if the problem persists. It's as if every time I contact Stealth, 90% of my points are overlooked and I get nothing so much as an apology. By this stage I can scarcely remember the factory settings, because I was foolish enough to not write them down!
Forum user "Remf" provided a list of CA V2.3 settings in an earlier thread, but I'm using a CA V3 so I had different menus to dig around to locate the settings.
(https://www.endless-sphere.com/forums/viewtopic.php?f=6&t=23996&start=4550)
As far as memory serves me, this is what I changed to remove the problem with the cutting-out motor:
Left Watts limit to 4900. (Stealth default)
Changed Amps limit from 65 to 60. (In Remf's replies, he states that stealth factory-tune their bikes to 60A, yet mine was factory set at 65A.)
Changed PSGain from 1.00 to 0.08. (Again, the value on the left is how the bike came from Stealth)
Changed IntSGain from 50 to 200.
Changed Throttle Output from 0.49-3.99V to: 0.49-4.98V. Changed fault limit to 4.99V.
Changed Vshutdown from 11 to 10.
Under the new settings full power is restored to the bike. Power cut off can still be experienced but only rarely and at full throttle; typically going uphill. This is most likely the Crystalyte Controller cut-off limit. Anyway, the gist of this is that I'm merely a beginner when it comes to the electrical aspects of the bike. Half of these settings mean nothing to me. The only reason I even tweaked them in the first place is because I assumed that if Remf says they are "Stealth defaults for Bomber CA V2.3" then surely they're safe for Bomber CA V3.0?
So to cut to the chase, does anyone here have one of the newer Bombers running CA V3, and is able to look through their setup menu and tell me what defaults their bike has? . A typed out list of defaults, whilst asking a lot of you guys, would be really handy. I'm reluctant to just do what Joe@Stealth says because putting the settings back to how I had them not only brings the stupid power cutoff problem back, but since the bike's been so problematic from the first, I'm not entirely confident it was set up correctly to begin with.
If anyone has any ideas what might be causing the problem please don't hesitate to let me know. Thank you all for reading this big wall of text and have a lovely Christmas!
