AussieJester
1 TW
OooooK then...so my trike wont be going today LoL
I had pretty much resolved myself to the fact it wasn't going to be a case of just plugging in the throttle wires
and hooking up the power to the controller and motor :: sigh ::
Thanks heaps for your time Methods, i'm still a little lost...
"Attach your main battery ground to J1-3 with a hard connection to your battery negative"
Run a piece of wire from battery negative to the J1-3? (I assume thin wire ~same size as the controller uses is fine for here)
Then:--
"Connect the positive of your battery to one of the main contactor lines"
Connect big MOFO thick wire to the metal '+' tab on the back of controller?
"Connect the positive of your battery through a small switch or key switch to the positive contactor coil"<-J1-4?
The next bit totally confuses me sorry mate :-(
"Attach the other side of the main contactor to J1-1 PWR
Attach the other side of the main contactor coil to J1-4 COIL DRIVER"
I am unsure of what you mean... You say "if i dont have a contactor forget 1-4" I dont know if i have one or not i thought the contactor were the three metal tabs 'B+' 'M' 'B-' on the end of the controller :-S
If i forget the step and go the other way well...there is no way i could hook my 'switch' up to the controller (its 200amp switch its HUGE i put on main leads from battery as a rule) that side it takes wires as thick as a pencil and the wires on the J plugs are thin as a pubic hair :-S all too confusing for me...
Onto J2 anywayz...
This i understand and have no probs with...
Sorry Methods, i understand the controller needs to be 'turned on' or have power applied and needs to be 'switched on' through J2 plugs/pins things im just a little lost as to how the wires are runninng with this 'contactor' you mention that doesn't appear to be the same 'contactors' im thinking are the ones on the controller ie. metal tabs 'B+' 'M' 'B-'?
If you could possible scribble a quick diagram
rather than schematic layout i will have your babies LoL Sorry for the denseness buddy im sure its very simple (to most) and when i see it in figure form it will click as im obviously missing something ...
As Princess Leia says "Help me Methods your my only hope..." well its something along those lines im sure
Appreciate your time mate
Kim
EDIT:-
I see now the contactor you speak of on the schematic sorry...so...i dont have one LoL... I drew up a lil diagram with 'my take' on the setup as best i can figure it out, is this even close to correct?
The J1 wires connected are the red and black forgot to lable in diagram...
Thanks again Mehods shall await your input before burning anything hehehe
Then:--
Onto J2 anywayz...
Kim
EDIT:-
