Jakolanternn said:
Hey boss, I can’t really answer any of the motor questions besides that it is geared, as there aren’t any markings on it anywhere, besides shimano on the gears and ecotric as the bike brand lol. But what could it mean if the shuddering and noises only happen when the bike is powered on and using the motor. On assistance level 0 it is all good. Keep in mind this is also the case if motor is on and bike upside down. I also opened up what I believe to be the actual battery of the bike? (Separate from the actual battery I attach/detach to ride with) inside there was one wire not connected to anything. I left the cover off and just let it hang for 10-15 feet while I tested it and it worked perfectly there as well. But the shuddering and sounds all appear to be coming from there
Hey I like you already, calling me boss!
Gears, I meant a geared motor internal gears. If some teeth are broken on the gears could shutter, but would with load more so then no load. Noises only while motor is on, could be anything: a loose hall sensor, burnt windings, lamination seperation, loose magnet. Could be many things.
Everythings thats been mentioned, sensorless controller does it to.
You need to systematically go through everything from one end to the other. Start with the throttle, look at the wiring from the throttle to the controller, are the wires not cut or damaged. Does the throttle twist smoothly. Next, are all the wires on the controller in good shape. Wires properly routed, not hitting a tire. Next, flip the bike upside down, move the wheel with your hand only, listen. Look at the axle, look inside the axle are the wires not damaged. Twist the throttle a bit, listen. Do everything again, go over each wire. Smarten up the wire routing with zip ties if you need to. Spin the wheel with your hand, listen, how does it feel? Spin it fast, spin it slow...all by hand, no power. Get a friend to twist the throttle, listen carefully. Next, you will have to open up the motor so get an allen key, take both covers off then get back to us.
Edit - I would start off by grabbing a spare throttle and hooking that up. You should have a spare throttle anyways, get two spares from here, and a sensorless controller to match your battery voltage and the amp discharge you want, yes you should have a spare controller too
https://evfittinggreentime.aliexpress.com/store/313864
First, open up your motor!
