John in CR
100 TW
While my 2wd monster nears road testing stage, it's time to start hatching the next plan. Since my son shows no signs of coming down to participate, it's time to go solo on building my coast-to-coast cruiser. For the first time I'll give real consideration to weight, so I'm going to put my Trek AL hardtail frame from an early ebike to use. I need to climb a big mountain efficiently, so hub motors in wheel are out. I want to make it flexible for which motor I use, though it will probably be a hub motor, either the tapped winding Xlyte 409/4011 or Grubee 500W hub motor I have. I will ventilate the covers for cooler running and quite high power potential, especially at 144 volts.
For simplicity and weight and space savings I want things to multi-task. My novel plan to do that is to use a rear hub as a jackshaft and combining shaft for pedal and motor power. This will mount directly in the rear dropout of the Trek frame. The novel part is that this will be an extended frame similar to xtracycle, and axle of the jackshaft hub will be the swingarm's pivot, saving space and weight along with making chain stretch a non-issue. To me this solves all issues of chainlines, and gives me multiple gears for both the motor and pedal assist, all very simple and without a bunch of bike mechanic stuff with which I'm only vaguely familiar.
John
John
