Kingfish
Greetings –
I was in a conversation the other night and we landed on the subject of Eddy Currents. Going through the math, it was my understanding that the calculation for determining the diameter of Phase Wire Conductors inside the motor is based upon the Motor Frequency – and NOT the Controller Frequency.
For the sake of discussion I am not concerned with core laminations; this is pure theory dealing with conductors in a rotating magnetic field.
Calculate RPM & Motor Frequency
OD = Diameter of Wheel (inches)
C = Circumference (inches)
C = OD * π
V = Velocity (mph)
FPS = Feet/Sec = (V * 5280 ft/mile)/(60 sec/min* 60 min/hr)
IPS = FPS * 12
RPS = IPS/C
RPM = (IPS/C) * 60
P = Count of Poles
f = (RPS * P) or (RPM/60 * P)
Make sense?
Therefore a 46-pole motor attached to a 26” diameter wheel at 40 mph should have an rpm of 517 with a motor frequency of 396.5 Hz.
Continuing… We can calculate the Skin Effect from the following formula:
δ = 1/(√πfμσ), where
δ = Depth (m) penetration
f = frequency (Hz)
μ = Magnetic Permeability (H/m)
σ = Electrical Conductivity (S/m)
According to the source, f in this case uses erpm:
f = erpm = (RPM/60)*(P/2); for the example above this value equals 198.2 Hz.
I’m a little fuzzy here: Is it because we only care about ½ of the phase? :?
The value of μ varies on the material; Copper and Aluminum are very close together, although not the same. And the value of σ is obviously going to be quite different between these mats.
The end result suggests that the equivalent AWG conductor diameter for Copper can be up to “00”, and “0000” for Aluminum. That’s quite a large conductor, and I am uncertain. :?
Seeking clarity, KF
C = OD * π
V = Velocity (mph)
IPS = FPS * 12
RPS = IPS/C
RPM = (IPS/C) * 60
P = Count of Poles
Make sense?
f = frequency (Hz)
Seeking clarity, KF
