Hillhater said:
Luke ,...please explain how those motors with a power density of 1kw/kg, bring anything to this party ?
.Tesla's motor produces 420 kW ( battery limited ! ). from its reported 150kg (350lbs) weight !...2.8 kw/kg !
If we used Thingap's technology you would need a 400+ kg motor for the same power ?
What am i missing ?
Arlo...i think you are the one who is missing the point..we are trying to get down to a DD motor . 1: 1 with wheel speed.
We are not talking about adding a trans, we are trying to eliminate the 175 lb Tesla reduction box.
So how do you make a motor of 3 times the diameter/ volume without a significant weight gain ?
.....500-600 lbs is ridiculous the leaf motor will do 250-300hp continuous and it weighs 120 lbs! Why you think you need 500-600lbs is absurd...
Simple deduction, Talking Tesla...the motor is reported to be 350lbs, basic maths tells us a motor 3 times the dia (and only 1/3 as long) , will weigh 3 times as much if similar technology is used , so 700lbs more.
Deduct the weight of the reduction box, and you have 525 lbs !.......but thats just theory guesswork
Tesla's motor weighs 70lbs check your facts. Skip to 42 min
[youtube]PULkWGHeIQQ[/youtube]
https://chargedevs.com/newswire/elon-musk-cooling-not-power-to-weight-ratio-is-the-challenge-with-ac-induction-motors/
And when you make it larger in length or diameter it does not proportionately grow in weight. Think hollow rotor. And if the power is enough then it will weigh the same this is what you are missing. We make It shorter and bigger diameter for more torque and lower rpm but the same power and same weight.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
[moderator edit to add transcript for the hearing impaired]
From the video above, starting at 41:35
"I've got a question about the uh Tesla automobile. I understand uh the drive motor is...on the order of 250 horsepower, and only weighs 70 pounds, which is multiple horsepower per pound. I never see, I worked in the transit industry, never seen, and looked, and other sources, motor other than weighs multiple pounds per horsepower. The opposite way. Uh, so, you have an advantage like, an order of magnitude. Um, some of it can be explained by high speed. Can you explain, uh, how you achieved that?
Elon Musk:...[talks about rocket turbo pump]...but for electric motors, uh if you have a properly designed electric motor, AC induction motor, um, getting high-power to weight ratio, and like a really great uh um response rate, like a low latency and all that, extremely low ripple currents and what-not. It just kind of comes naturally to an AC induction motor. But the bigger challenge is actually um cooling it effectively, and in particular, cooling the rotor. You got a rotor going at like 18,000 RPM, so in the Model S, we coaxially cool the rotor, um in order to have high steady state. So, also, for an electric motor, you can have, its easy to get uh peak power for a short period of time. Um, It's hard to have sustained peak power, and, because you overheat. And then uh it's hard to get high efficiency over a complicated drive cycle. Um, those tend to be the problems you wrestle with more than say the peak power. Like, we can get peak power pretty easily, but sustained power power and efficiency over the drive cycle are hard..."
