4TKR
New here
I have built an electric cart for my wife to get around our small acreage as she is not very mobile. I am hopeless at electrics and need some help in wiring it up.
It has a 24v 500W motor, ignition switch, twist throttle and forward/reverse switch. these run through a 24V 500W controller and 2 x 12 v batteries wired to 24V.
I can get it to run with just the twist throttle and ignition switch but as soon as I wire in the FR switch the wiring starts melting and the controller burns out.
I have found another controller with just a FR switch and wiring to the batteries and motor.
Can I run 2 controllers - one for FR switch and the other for the ignition switch, twist throttle and battery charger?
If so, how do I wire it up and do I need relays in the system?
Thank you
Frustrated...
Thank you
Frustrated...
