Some new updates:
I received almost all the necessary hardware to get the bike running, yay!
New handles:
New brake pumps:
(these are "chinese versions" of brembos, so that was dirt cheap, but they do feel like really nice quality, it was a good find)
And, last but not least.... The massive Kelly KLS72701 Controller!
This controller features variable regen. I'd like to try using it, but I'd like to limit it to a relatively low level in order not to mess up the battery too much. Also, I'd like to keep the hydraulic brake for obvious reasons.... But Ideally, I'd like to operate both of these with one single lever.
So I had this weird idea I'm gonna test: using a clutch actuator to command a cable throttle. I'll parallel the rear brake system to this little actuator. The idea is that whenever I press the lever, brake fluid will first push the actuator since there's very little resistance there, moving the potentiometer until it reaches the full stroke of the actuator. Then once the actuator is maxed out, pressure should increase more and more until the brake pads press the disk.
In theory this should work, but I'll have to reduce the internal volume of the brake pump cylinder in order to use less lever travel to max out the potentiometer.
Anyway, I'll try that, hopefully that will work.
Also working on a sytem to better enclose and connect my ANT BMS. This BMS is really nice, but the main flaws are that it doesn't come with an enclosure, and also you have to solder the power wires directly on it, which I find extremely unconvenient.
So I bought a 100x100mmx4mm pure copper plate, and used my trusty hack saw + file to create those two bus bars.
They will be soldered to the BMS terminals, and then I could just use a screw to secure the power wires to it.
I'm in the process of designing a 3D printable enclosure for it, hopefully it should be nice.
Now that I received the controller, I can finally check how to actually fit all this hardware into the bike. So far, I'm leaning towards this configuration, which is very compact and gives the lowest possible center of gravity, while making everything super accessible and using very short power wires. No real downside aside that it will make cooling the controller a little bit more complicated, but that something I can easily fix with an air scoop on the bottom of the bike, or even later with water cooling if it turns out to be necessary (but it won't).
Now I need to replace this cutting board wih a metal bracket, probably some CNCed aluminum. The battery will be secured in place by pressing it from the top using a metal plate. I'm thinking of using either rubber mats or velcro bands to totally constrain it and forbid any kind of side movement. Simple, cheap, lightweight and probably effective.
Also took the bike outside to see how it looks like from a distance. So far I really like it, it's weird but it looks fun.
