If you are using platsil (platinum cure silicone) or tin cure, and something like the silc-pig pigments SmoothOn sells, you only need a *teensy tiny itsy bitsy*
amount of pigment to make a very solidly colored item.
If you use more than you need to...you get pigment leakage at the surfaces.
However...under weathering conditions, even with "just right", some of it (along with silicone oils that are in the silicone itself to make it soft) can slowly "leak" out, and may end up on your clothing if you don't cover the silicone with some sort of cloth, etc. I would recommend a simple top-wrap of spandex that tucks down into the seat frame under the silicone pad, since it will be able to be stretched over the pad to form fit it.
Also, to be sure you are thoroughly mixing everything, first put just a teensy bit (I mean, really teensy!) of your pigment into part A (or b, but only one!). Then stir that up thoroughly by itself to be sure it's the kind of solid color you really want making sure you scrape the sides and bottom of container. If it's not solid enough, add a *teensy bit* more, and restir, making sure you scrape the sides and bottom of container. Then repeat until it's as solid as you want it to be.
Only when that is done, and it is consistent in color, then mix that with your other silicone part b (or a), and mix until it all looks the same color and solidity, again making sure you scrape the sides and bottom of container.. Then you know it's all mixed thorougly.
This works better if you have an end color that is made by mixing two other colors, because then you can put the right amount of each into part a or b respectively, and only when they are correctly mixed at the end will the right color show up--if it's not the right color it's not mixed well enough.
But this takes experimentation and good measuring of color amounts vs material amounts, or experience with color mixing, etc., to get the exact shade you want if that matters for the application.
But it works ok even with just one color in one of the two parts.
