Things we still need to know:
1)
If the phase wires are disconnected while you are moving (free or under power) and then reconnect after say 25ms, will any damage come to controller or motor?
This was discussed but I don't remember it being decisive.
The best is to release the throttle while switching from one mode to the second mode.
I did both situation... switching phase wire while moving and when the bike was not running. Dammage to the controller may appear if you switch while the current is very high... ( voltage spike that mosfet dont like may occur as current is higher)
having high mosfet voltage tolerance.. like 4310 and 4110 will help... but i would not recommand having battery voltage too close to that... ex: i did use 75V battery on my 100V fet controller .. and i think this is borderline.
you must pay particular attention when you go back to the wye... cause the rpm of the motor will be higher when in delta than in wye.. so the voltage of the motor may be higher than the battery voltage.. so if you have 75V battery.. ad that you are at max speed, you may get more than 100V generated by the motor when going back to WYE...
ex: max speed reached at 75V in WYE:60km/h
switching to delta will increase speed around 80-85km/h
BUT if you are at 85kmp in delta and switch back to WYE, at that speed and having WYE the voltage will be above 100V...
when you run in delta You MUST wait until the speed is reduced to the point where the WYE max speed is reached to switch back to WYE.
caleb7777 said:
2)
Is there an optimum rpm to shift at to delta or star and how can one figure this out?
a) for maximum efficiency
b) for causing no damage to controller or bike
A) for max efficiency you should switch to delta at the speed where you begin to loose acceleration... it is always a point where from 4-5km/h from the max speed you dont have any considerable acceleration and will reach your max speed slowly... this is because the back emf produced by the motor correspond to a very low voltage difference between the motor and the battery voltage and the current decrease naturally... so acceleration NEED current.. so to get more current at that max speed, you need to switch to delta.. current will increase and will make your bike accelerating again.
B) for causing no dammage or reducing risk of dammage, i would not recommand to switch in delta when your WYE speed is still between 0 and 60% of your max speed in WYE..
ex: speed range in normal WYE: 0 to 60km/h
safe WYE speed to switch to delta: 40 to 60km/h
Doc
