Did you switch the relays under load?Doctorbass said:Oh.. I must sa... YES I had relay failure in the serie parallel setup.. contact of the relay blasted and alot of carbon on them... some was stick to close position!!!.. making short when i swtiched them to serie to parallel...![]()
High power + relay inside = BAD idea!!
The first to put 12 wires IS MARKCYCLE with the MH602. He posted pictures on his blog.. impressive stator !!!
Doc
markcycle said:Did you switch the relays under load?Doctorbass said:Oh.. I must sa... YES I had relay failure in the serie parallel setup.. contact of the relay blasted and alot of carbon on them... some was stick to close position!!!.. making short when i swtiched them to serie to parallel...![]()
Doc
I'm bring the throttle to zero then switching so far about 60 miles and no problems. I'm working on a circuit that when I switch it brings the throttle to zero first waits 100ms or less switches then returns the throttle. Switching with current in the phase wires will destroy 12 volt auto relays really almost any small relay.
Mark
Problem is, vibration doesn't ask if it's ok to switch. :lol: I'm pretty sure that's what caused the relay issues for him (and possibly others if they've tried this with similar problems).fechter said:Ideally, there could be a circuit that measures the current and does not allow the relays to switch unless the current is near zero, like a zero crossing detector.
rkosiorek said:now the problem of how do i get 12 decent size wires out of the case is the next item to solve.
rick
Larger bearing ID same OD = hard to find may not exist.John in CR said:rkosiorek said:now the problem of how do i get 12 decent size wires out of the case is the next item to solve.
rick
Rick,
That's the easy part. Find a bearing with a significantly larger ID than the current one. Then make a steel bushing with an ID to fit the axle, and OD to fit the bearing. Drill holes in the bushing to pass the additional wires. Be sure to secure the bushing to the axle in a manner so it can't spin.
John
oldswamm said:Hi,
Doctorbass,
<snip>
Isn't this motor wound as 12 windings in a series for each phase (as you progress around the stator)?
Couldn't you cut the wires and seperate them into 2 halves (on the bottom, opposite where they normally come together), which you could series/parallel switch, so a 5304 could be the equivalent of a 5304/5302. Or cut them in 2 places for a 5304/5301-1/3 (if you could bring out 16 wires).
(And as a disclaimer, I've learned as much motor tech in the month I've been lurking on ES, than the previous half century, so I DON'T necessarily claim understanding.)
From what I've read, I don't think the relays in the hub are ever going to be dependable enough tor short term (racing) or long term. AND, I don't see a reasonable way to do it electronically, (back to back 'intelligent', floating (optoisolated), mosfet circuits, back to back floating SCRs?).
Bob
oldswamm said:(Don't like to be told I can't do something.)
Im thinking it is a combination of things for one when you run them in paralel it will be more load on the controler and if you go from 12 in series to 6 in series then paralell the other 6 it is 4 times the load on the controler!oldswamm said:Well, some of the most respected names on this forum have read my posts and decided I wasn't worth explaining it to.
I guess I'll erase all my messages and apologize to the forum for wasting your time, but I really wish just ONE of you would take the time to explain WHY the idea is so idiotic it's not worth commenting on..
You don't have to go into detail here, just post a link that will explain WHY a motor won't work unless all the windings of any phase are in series. It's been over 30 years since I studied motor theory, and I honestly don't understand why the windings can't be paralleled. I always just assumed it was because they didn't want to make 2 splices for every winding, which you have to admit would make motor assembly WAY more difficult.
It seams SO obvious to me that it would work, and I've given it a lot of thought and can't see why a motor won't run unless all it's windings are in series. The only 2 readers who have bothered to take the time to tell me I'm an idiot, obviously KNOW why it won't work, but for some reason don't want to give me, or point me to, the explanation.
Bob
Arlo1 said:Im thinking it is a combination of things for one when you run them in paralel it will be more load on the controler and if you go from 12 in series to 6 in series then paralell the other 6 it is 4 times the load on the controler!
Another thing is it doesnt matter the winding style in the motor it will still have the same acceleration! The only thing winding determines is top speed!
