thebikestore
10 µW
- Joined
- Mar 10, 2020
- Messages
- 5
Hello, I own a bicycle shop and a customer brought in a bike with a broken throttle. The old throttle has 7 wires and the new throttle has seven wires, but they are not the same colors. When plugged in where the connectors fit, nothing happens.
The motor cuts in and out when the wires are wiggled on the old throttle and disassembly showed signs of arcing and a disconnected wire, the green wire.
I have tested the battery and it is fully charged.
The controller says it is a Santroll WZKH3616KA-OK 15a / 36v
The new throttle is an AlveyTech T53-6144
https://www.amazon.com/AlveyTech-Throttle-eZip-Trailz-Electric/dp/B06X1B4PPD
Coming off the controller there are;
1 red/black Female,
2 yellow/black Male(brake kill attachments) One has an extra red/black Female connector and the other one has a cut brake kill wire(blue/red) plugged in. This was done when the left brake lever was replaced I assume.
1 Three pin Male connector Green/Red/Yellow
The old throttle has;
1 brown/white male
1 blue/yellow male
1 red/black/green female
The new throttle has;
1 Battery Gauge grey/green female
1 PAS/TAS Button yellow/brown male
1 HAL sensor red/blue/white
Will this throttle work with this controller and what wires do I need to hook up on the new throttle to the controller?
Any help would be greatly appreciated.
-Mike
1 red/black Female,
1 brown/white male
1 blue/yellow male
-Mike
