electraflyit
Are the 900w still availible? Can't see them on the BMS site
Eddie
Eddie
megacycle said:I wonder what the difference is between my RSP 3000W im using and ecity 2000W.
The RSP being only 4kg with about 0.5kg of case and bars.
NeilP said:Ref EMC 1200
rolf_w said:1 = W503 ; turn CW to increase V_out ; range 57V - 116.5V if W4011 set to max V_out
1a = W502 ; is for ??? (not mounted)
2 = W501 ; is for LED lamp indicator adjustment
3 = ?W401? ; is for current adjustment (can't see the label)
4 = W402 ; is also for current adjustment ( probably the fine or coarse)
5 = W4011 ; turn CCW to increase V_out ; shifts the range of W503, kind of offset?; I tried W503 ranges for a number of fixed W4011 positions e.g. 47.0-105.7V, 42.5 - 96.0, 32.5 - 73.5, 28.0 -63.5; I was able to trim down V_out minimum to 2V!
6 = ?
7 = ?
rolf
6 = Display voltage calibration
7 = Display Current calibration
dnmun said:the transformer cannot be replaced. it is easier to just buy the right charger.
