pwd
Continuing work getting the motor to fit well. In addition to getting the axle shoulders spaced correctly, I also had to make sure the brake plate was going to line up. I used 3 large washers with an ID of about 20mm for the axle. The trick is to then put a bolt and another washer between the inner toque plate and the brake plate for a tight fit.
Test fit:
Having inner toque plates made mounting the wheel a bit of a challenge, since the toque and brake plate has to line up with a knob on the inside of the chain stay. I couldn't just slide the motor on, it had to go in on an angle so I could fit the brake plate slot through the frame "knob".
Example with the old motor:
Mounting the tire and valve stem was a job on its own but it worked out well. I had to go with a 90 degree valve stem so it would clear the motor casing. Went with a Kenda K413 130/70-12 because it was less expensive and looked like a decent tire.
This morning I had my first test ride with the new setup. The 3 speed switch was nice for getting used to the bike. I have a bit of regen working on the controller and will turn it up once I'm more conformable on the bit and am sure the axle isn't going to wiggle loose.
I know the 3 speeds are unique to my bike's programming but here were my impressions:
Speed 1 - Ok - pretty much like it felt in stock form with a limited speed: good for a legal mode
Speed 2 - more acceleration (just enough to match average green light take off) and can cruise along with city traffic nicely (probably up to 65 km/h)
Speed 3 - uncorked: rocket like acceleration with no speed limit - I also think that field weakening is kicking in. Max battery current set to 150A and max phase set to 530A.
battery pack was low and only stated off with 3.6V/cell and ended at about 3.45V/cell - I probably should have charged it more before riding but I couldn't resist.
The bike is very much in an unfinished state with no fairings, lights, horn 12V, ignition switch or any sort of display. I also need to tune the controller some more and get more comfortable with the Fardriver Android app.
Here it is charging before it's next ride...
Test fit:
