Hi everybody!
Quick update and pictures to show the parts I receive from
http://diyelectricskateboard.com/:
http://image.noelshack.com/fichiers/2015/40/1443719647-wp-20151001-12-28-39-pro.jpg
Got to say thanks to Torqueboards for the very quick delivery, 6 days from order to France, unbeatable; packaging was great.
Got sensored motor instead of unsensored, but I figure Torqueboards may not have unsensored anymore (or a mistake in order but seriously doubt of that).
Already fixed the motors to motormouns, then fixed to trucks with I think very good alignment (tips cardboard creased 3 time and set between motor mount and wheel pulley. Very little Dremel job on the Keyway to fit motorpulley.
Little issue about way to fix motor on plate because with 180mm belt and my 36/16 ratio just can't fit motor in a way where wires will be oriented to trucks, the motor mount is nearly to minimal position option; not a big deal but will consider a longer belt maybe 190mm to fixed this just to put less stress on wires while turning.
Can also do like okp and fix with dremel, but don't want to weakened structure of the mount.
So this can be a little improvement that Torqueboards will consider for his motormount, or just recommand longer belt :wink: . ; maybe holes in the sliding parts to allow wires management (not sure if i'm clear sorry)!
Next picture will show you all the stuff on the board, to have a global view.
http://image.noelshack.com/fichiers/2015/40/1443719650-wp-20151001-18-40-20-pro.jpg
Got to think about management because of the short wheelbase here (24.5"), probably have to cut some excess wires but have to consider good sizing cut in case of changing the deck in the future.
question: I got 5.5mm plug for motor because of my First order with Alien Power, here with DIY motors small sized plug (probably 4 or 4.5) is replacement with mine will be an issues?
Thank you all for reading, and update will probably coming on monday (nightwork this weekend
SYL.
