ejonesss said:will the new design allow the use of a standard car battery charger? or even the 5 or 12 volt output from a computer power supply?
ahambone said:Hello Everybody,
Long-time lurker, first time poster. Thank you to everyone who has posted over the last few months and makes this thread really enjoyable. Gary, when the new 24s BMS boards become available you can count on me ordering a couple for tinkering with them as full blown EV-car BMS.
On a side note for everyone in this forum, I have an interesting lead on LiFePO4 cells. Like everyone else here, I keep looking for a more legitimate way of finding A123 caliber LiFePO4 cells (beyond their developer kits and gutting DeWalt packs). I found a vendor (http://www.voltphreaks.com/) that sells loose 18650 LiFePO4 cells online at reasonable discounts. Their cells are smaller capacity than A123's 26650s that I've been testing against but they look like they are cheaper Wh/$. I wouldn't mind soldering 3 or 4 of these cells together to replace and A123 unit. I have ordered 80 of their cells to play with (you have to order 50 to get a volume discount). If anyone is interested, I will post my testing results to the appropriate forum.
Cheers,
--Adam
fechter said:ejonesss said:will the new design allow the use of a standard car battery charger? or even the 5 or 12 volt output from a computer power supply?
Yes, just about any source that is current limited and has enough voltage will work.
A car battery charger might be a bit low for 4 cells and certainly a 12v output from a PSU would be too low. You can tweak the voltage up on these in many cases.
dnmun said:. . . mr jonesing, if you will go back and read through the thread from the start . . .
I'll be using it for 12 TS cells, so I'll have to experiment to find the right components to get the 4.25V cutoff.
thomson2008 said:The kit includes the following: 4-channel LVC board, 5-pin male balancer/charger plug, three inter-connection G10 plates with nickel-plated battry springs and copper straps which are used to connect the four cells in each block in parallel, one G10 bottom plate with attached threaded rod, and a 14" length of black 5"-wide PVC heat shrink tubing. Also included is all required hardware (nuts, lock washers, etc.).
_______________________________________________________________________________
Carhartt Work Pants budapest property
methods said:I know that I am way late in this thread. . .
Is there any way to lay the pads down on the for the TC54 that would make it easier to fit the more common SMT parts in addition to the dip?
I am betting that I will be able to solder the smt's anyway but a small pad would make it easier. I have a microscope and infinite patience. . .
After long hard thought I decided that I must go with 3.0V LVC to protect me from the scenario where I leave the bike on and forget about it for a weekend.
If I were to go with a 2.7V LVC Murphy would without doubt come to tell me about his law.
-methods
GGoodrum said:methods said:I know that I am way late in this thread. . .
-methods
Even using the 3.0V TC54 parts won't help if you simply leave the controller on. By using the ebrake line, what happens is if a TC54 trips, it is basically just killing the throttle. In order to prevent true bonehead moves, like leaving a controller on, which I myself may, or may not have done (), we'd have to add Randomly's active cutoff feature, and add a couple more 4110s to control the negative pack lead. Actually, maybe what I will do is a small board, just for this function, unless it is something that everyone can't live without (true active cutoff...).
ejonesss said:correct me if i am wrong but what you are describing is.
GGoodrum said:... In order to prevent true bonehead moves, like leaving a controller on. . .
Patriot said:I have a really dumb question.
If I build a battery pack using 32 cells that are 3.2v/10ah each, in order to make a 48v/20ah pack, would using 2 BMS's be the best way to go?
I intend to build the pack like this. 16 cells in series to create 2-48v/10ah packs. Then, wire the two in parallel to create one 48v/20ah pack, right?
So, wouldn't having 2 BMS's be the best way to rie up, and balance each individual cell?
I've never quite understood how they build a 32 cell pack using only a single 16-cell BMS. Unless the wires are spliced to serve two cells in parallel for each 10ah pack somehow?
Someone please enlighten me out of my ignorance.![]()
