Hi that's my bms capacity from bmsbattery.com
It 's connected to 16 headway 38120 10Ah
The charger is a 400 watt charger for lifepo set at 58,4 v
After 1 hour charging, cells in the negative pack side go in over voltage.
This cause stop and go the charger. It's impossible to arrive to 58,4v because other cells are at 3,40v.
More one goes towards positive and the voltage decreases.
First cell in negative side is 3,9v and last cells is 3,3v
Is this a bad BMS ?
Why does this happen ?
Do your bms have this problem or i can buy it without any problem with headway cells?
Is this a bad BMS ?
