This is all looking very nice chaps. I'd just like to second indubitably's suggestions of an idiot's guide. As both this analogue BMS and the cell-log based setup appear to be coming to fruition at much the same time the number of possible options has grown rather, and I know I'm not sure which way to jump. Something describing the pros/cons, pyhsical arrangements, layouts and connectors of the various options would be marvellous. I realise that probably needs to wait until the final boards and BOMs are actually done - there are only so many hours in the day. I think the cell-log-based scheme is probably most pleasing, especially as I can use the celllogs to make poor-man's manual balancing less painful in the meantime. (Do celllogs come with a connector pigtail or not?)
I know I am getting very bored of manual-balancing on a weekly basis (even if I have taught the wife to do it now, as she's using the bike
, so the tantalising nearness of actual product is great. I've been holding off buying connectors for the packs, waiting for it to become clearer how things fit together. I'm still a bit vague about that: It looks like fitting 5-way JST-XH female connectors to my (4 off 4S) packs is likely to be compatible, except that I'm not sure if 4S/5way connectors will go into the 9-way connectors on the 8-Channel LVC + 4p Parallel Adapter for example? Or if I'd need to either have a Y-cable for 2x 4S-> 8S , or change the male connectors on the board to be 5-way, one row offset to the left end, one to the right end, or fit offset 9-way connectors to each 4S pack so they plug nicely in to the 8-channel boards. How is this normally done? And are the connector options the same if I go the analogue route? It's all very hard to work out without the boards in front of me, but I'd really like to get some connectors on my packs now as it would make manual balancing a lot less fiddly.
And where does one buy connector parts? Tpacks? hobby-city (They have a lot of prepared JST-XH cables but I don't see pigtails, nor 9-way connectors). Digikey seem to have everything but that way I get to do a lot of dull crimping without the right crimp tool.
Any clarifications would be most welcome.
Sorry for the noobish questions, but I suspect I am not the only one wondering about these things. My credit card remains poised, so here's hoping you won't find any more issues requiring respins.
Oh and one last thing. The meanwells draw about 6W after they have turned down the output current to zero, which is annoying. Your control stuff is only working on the front-end DC, right?, so nothing will actually switch the PSU off completely when charging is done? I'd have to think up some scheme with a relay on the AC side to actually kill the parasitic overnight drain?
