GGoodrum
The CellLogs don't do anything for balancing. They are just monitoring devices. They do have LVC and HVC functions that will trip an alarm output, but these need to be isolated with an optocoupler. An optocoupled HVC signal could be used with the MW Charge Controller to keep a cell from being overcharged, but it would simply limit the current to all the cells. It does nothing for balancing.
Getting back to the full BMS, I just got some test samples of the following:
These are the 3 x 8 version of the 24-Channel full BMS. There is also a 4 x 6 configuration, but I only did a test run of the 3 x 8 version. Here's what the two look like together:
They both share identical charge controller and "smart" LVC active cutoff sections. The latter function can differentiate between hard, under load, LVC "strikes", which will pull down the throttle signal, and slow drains like leaving a controller on. In the latter case, the main power will be cut. The charge controller does HVC throttling/protection and it has the low current/end-of-charge auto-shutoff function.
This is about as close to a "finished" version as we can get. The 1A shunt cell circuits have been well tested. The only difference between the two versions is basically how the connections to the cells are made. The charge controller and active cutoff sections have also come from previous, well-tested variants. The only thing we haven't tried is everything on one board.
I've gone to great lengths to make this as "one-size-fits-all" as possible. Actually, it is more like two-sizes-fits-all. The 3x8 version can be cut down to a 16-channel variant, and the 4x6 version can be made to work with 12-channel and 18-channel setups. If active cutoff is not used, this section can be trimmed off, or left unpopulated, as can the charge controller section, if a MeanWell supply, with a companion MW Charge Controller, is used. Both boards are designed to fit in a pair of Hammond extruded aluminum boxes, stuck in a side-by-side configuration, but both of these can be used like the previous v2.x versions, in a standalone fashion. In this case, however, a larger heatsink bar should be used across the shunt resistors. In the "boxed" version, there is a 3/16"x3/4" bar that goes between the shunt resistors, which are mounted from the bottom of the board, and the bottom of the case(s). This allows the whole case to be used as a heat sink.
One of these test boards is on its way to Andy, and one is going to Richard. I will build up one as well, but probably only 8 channels. I just need to verify the proper operation of the charge controller and "smart" active cutoff sections. Anyway, my hope is to put in "production" orders for both variants by the end of this week, or the first part of next week. Not sure of the cost yet, as it is totally dependent on quantities ordered. Just to be clear, I will only be offering the PCBs-only. no kits. There will, however, still be BOM Import files for Mouser and/or Digikey (they now also have a BOM import function...), to automate the parts ordering, and an illustrated set of assembly/test instructions. This is still basically a DIY application, and this shouldn't be the first printed circuit board you've put together/soldered. For those wanting an assembled version, you need to contact Andy (AndyH here...), but not until he's had a chance to do a build/test unit.
I know this is about two years late, and not something a noob might want to tackle, but the result will be a fairly capable system that can be adapted to a wide variety of configurations.
-- Gary
-- Gary
