PJD
In my case with an older board, once all the LED's are flashing, the charging current continues to decline, and the master LED only gradually changes from red to orange to yellow to greenish yellow. I am assuming that although all the shunts are on, they are still on a low-percent duty cycle, and the the cells are still taking current, so I have been allowing about 45 minutes after all LEDs are on before I consider the pack fully charged. If the charger is left on for about 1.5 hours or more, the LEDs will stay lit, then fade off over several seconds, after the charger is shut off. I interpret this to mean the charge sufficient so the cells are passing practically no current, and consequently, their voltage is constant, and apparently slightly higher than the shunt voltage, so the shunts must "bleed" the voltage down when the charger is shut off
So with your current version, I am concerned that the charging will get cutoff before the cells have seen a full completion of the CV charge cycle. Is this a concern?
