I have a quick question..I am planning to use this BMS with a large lifepo4 pack. I will be using this charger: http://www.bmsbattery.com/product_info.php?products_id=111&osCsid=2726a892cc5a75adbe3f1f57c9f3edd7
Data sheet here:
http://www.ecitypower.com/pdf/w3k.pdf?5a8729d658601922ad7447e28083cf65=c918d35f86836df3b488a1d58d46f4eb
I have been skyping back and forth with the owner of Ecitypower, Jack (very helpful and quick to respond to queries btw) and he is convinced that if I used this charger with the G/F BMS that it would trip the charger off accidentally, and the charger isn't capable of automatically turning itself back on. Here is what he said verbatim
Is there any merit to this? My understanding of the 4.0 BMS is that PWM controls the current to individual batteries, and that the batteries would never appear "disconnected" from the charger at any point. I could be completely wrong, but I'm sure one of you guys knows the right answer!
Data sheet here:
He says that the charger has built-in protection to turn itself off if the battery is removed while charging, and his concern is that the BMS would fool the charger into thinking a battery is not attached as it is balancing, causing the charger to shut off before balancing could occur.The CV stage is often used for BMS balancing. It is long time stage. When one cell goes to 3.65V and one cell is 3.00V,I think your BMS will cut off the circuit for charger.
