Thanks to the community here at E-S, and all the cool projects you have pioneered, I was able to create this blue daily commuter. I used to bike to work occasionally (10 miles one way, fairly flat) but arriving to work sweaty is not a pleasant situation. I wanted to make a fun, reliable, safe commuter that had a beach-cruiser vibe and a little style. The point was to be fun, practical, and get off oil! Sometimes I feel like the only vote that counts is what you do (and don't do) with your money.
I found an inexpensive EVG bike on craigslist. I really only wanted it for the awesome cromoly frame. It keeps the battery low and hides all your electronics behind fairings. Clean. The stock shifter is also set up perfectly for an ebike. The battery was dead but the rest of the bike was in great condition (minus the scratched up fairings). The plan was to upgrade the bike with a small budget, putting the most emphasis on the battery. Paul (cellman) came through and made a battery that fit my specifications EXACTLY. The battery arrived this week and yesterday I went on my first e-bike ride ever. I AM HOOKED!
So here's the build:
The night I picked it up:
The teardown. The stock controller and motor get boxed for a member here on E-S.
Used my automotive tools to remove the stock sprocket The size of that front sprocket is just silly.
Flipped the stock chain gear and then bolted a 52T to it with some 9.8 grade bolts I had lying around. Had to shave a fairing mounting point slightly to make it work.
This larger sprocket required some hacking of the stock fairings and a larger chain.
Sent cellman some measurements for a 52V battery. This bike was designed to have a battery there, and that's exactly where I want it for handling purposes. This chromoly frame is built like a truck, I love it.
The stock black fairings were beat up and scratched. I envisioned an Avatar look for the bike, so I attacked it with an airbrush.
Strontium aluminate glow freckles. :wink:
Bought a 12V MR16 400 lumen LED spotlight off amazon and fit it into the stock headlight. Works great for my purposes.
I originally bought a 500W motor, but the axles weren't machined in the same plane. Yescomusa took my return and I chose to upgrade to a 1000W. (Change of heart, thanks E-S ) Also bought blue tires.
Added a 11T freewheel from sdelectricbike. Had to dish the wheel to make everything fit.
Test fit the updated fairing:
The new controller fits perfectly. And cellman's A123 battery fit the frame like a glove:
I rewired all accessories to 12V, using Lyens DC-DC converter. Took apart the taillight and rewired it to accept 12V input. The stock horn works on 12V too. Also added some 12V LEDs.
Finished:
And some green underglow for evening beach crusing
Finished:
