Just bought a used 2009 eZip Trailz and all is perfect except...
Do I do anything to activate PAS? I believe if the battery is on and the switch is in PAS, all I do is pedal and it will pick up. Works fine in TAG.
I have tried the throttle but it doesn't affect it at all.
There seems to be no instructions in the manual and I may just be stupid here.
Any instructions?
Electrically all is well but the pesky PAS is dead. Brake interlock is fine. Disconnected and connected all connectors.
I've went thru wiring and looked at the obvious, the sensor. I don't know how anything could go wrong here just a sensor and magnets. Adjusted several times, no change. Can I take a meter and see anything at the connector as I turn the pedals? Seems should have a pulse or something. Anyway, please help.
Don't want to invest in a controller. Would double the value of the bike.
Bottom line, is there a general troubleshooting guide or process to narrow down to sensor or controller?
Thanks in advance.
JIM
Any instructions?
Thanks in advance.
JIM
