dogman dan
1 PW
I keep having this fantasy for a race bike. Dual hub, with two controllers. The front hub would be something fairly mild, like 1500 watts and a top speed of 30 mph. The rear hub would be crazy powerfull, more like a dragster bike. The rear hub would have a throttle and a monster controller.
The front hub though, would have an ebrake cut off, and it's throttle would be set to the max and locked. There would be an additional kill switch on the bars too.
In a race on the kart track it would work like this, the front hub would pull constantly, unless you pulled a brake lever. The power of the front hub is primarily used simply to improve your traction in the corners, providing a steady pull all the way through, but not really accelerate you. When you got to the wider corners, you'd add power with the rear motor. On the straight, you'd grab the rear hub throttle and smoke the rear tire with 6000 watts.
Not that I could handle such a beast, but I can in a fantasy. But would it get too inefficient? with the rear hub having to drag the slower front hub down the straights? gearmotor for the front?
