webmonkey8
10 µW
- Joined
- Aug 14, 2015
- Messages
- 6
Brentis said:Got fat pockets? :wink:
I definitely don't have fat pockets!
macribs said:Hard to see but the fatbike is actually following some tracks laid beforehand and the mtb is peddaling pure powder.
The way the mtb got stuck is much the same experience I had last year on a fatbike. The tires would not float and I could not get any speed, if powder got to deep I got nowhere in fact. Seems I should have played around even more with the air pressure so I will have to try it again this winter to give a conclusive verdict about fatbikes for fat asses. My initial feel last winter was that for heavy riders fat bikes do not work on powder snow. But riding a laid path or track works fine even if the track is not hard packed.
wesnewell said:This is about the dumbest comparison I've seen here. And I've seen a bunch on es. Unless you can reach hydroplaning speeds, a wider tire will always give you better traction than a narrow tire, given the same tread design. Dry, snow, ice, rain, it doesn't matter. The more rubber on the road surface will always give better traction. This has been proven time and time again by tire manufacturers. And fricking common sense should be enough.
wesnewell said:Unless you can reach hydroplaning speeds, a wider tire will always give you better traction than a narrow tire, given the same tread design. Dry, snow, ice, rain, it doesn't matter. The more rubber on the road surface will always give better traction. This has been proven time and time again by tire manufacturers.
wesnewell said:http://texasalmanac.com/topics/environment/extreme-weather-records
Wheazel said:I have experience from 8 years of wintercycling here in Sweden. I have not tried a modern fatbike, but ive tried different mopeds which should replicate the effects to some extent. My own conclusions are as follows:
When biking in untouched powdery snow no tyre will float unless you have something snowmobile track wide. Narrow spiketyres win as they roll with lower effort.
On new wet alittle heavier snow, you can be better off with wider tyres like fatbike tyres if they mange to float.
If the snow is fresh but very icy and dense (fell during windy conditions and consist of small ice particles) Then a narrow tyre is better.
The narrower the better to reach the surface under the snow and get a grip there. Wider tyres are all over the place in this kind of snow.
This also applies for snow that gets mushed and crushed by cars to a snow-ice sludge. Regular and wide tyres suck in these conditions.
For these conditions, one would be better off riding with circular sawbladesIf the tyres were wide enough to float on this surface, it could be an improvement.
That probably wont happen with 4" wide ones tho.
These are the most demanding conditions to bike in my opinion.
Uneven and/or icy surfaces are easier, and handled with suspension and good spiketyres (of any kind). Which pretty much means 26" tyres.
Wheazel said:Thats intresting, in the sludge that develops from cars mushing the snow around, I feel that a 2,5" tyre works worse than a 1,5" tyre to name an example.
At what width do you recon the tyre stops going all over the place? 110kg total weight with standard 2 wheels.
