dangerzone said:
Well, it seems Luke is on the right way, these Sevcon controllers seem to have some similar FETs inside:
http://www.sevcon.com/PDFs/G80%20Datasheet%20G801109B.pdf
I've never seen inside a Sevcon, but the two I've seen weren't big enough to have housed the Ixys FETs that Luke and I have inside. Also, the Sevcon isn't a 200/300V rated controller as you enquired about, it's 116V max, which is still just inside FET territory. My guess is that the Sevcon is like pretty much all others and uses an array of smaller package FETs inside.
If you want to operate up at 200 to 300V, then, as I said before, you're definitely into IGBT territory; FETs will simply be too lossy at these high voltages. If you are happy to bring the voltage requirement down to around 80V, then the biggest of those Sevcon controllers you linked to would handle about 17.6kW continuous, well short of your 60kW requirement. It's thermally limited in its current handling capability, so would handle 44kW for two minutes, but this is still well below your requirement. The I²R losses in things like wiring, the controller, the motor and the battery internal resistance start to get very high when you lower the voltage and increase the current to get this sort of power. Your original desire to operate at 200 to 300V makes a great deal more sense than running at the 80V maximum of this Sevcon unit.
Jeremy
