I have not had a flat for about 5 years over approx 8,000 miles among my 3 bikes (mid drive and a moped), until 2 weeks ago when I got a flat on the rear of my TSDZ2 mid drive with Fincci tires bought 6/2024. The flat turned out to be on the rim side of the inner tube, not from road debris. The rim tape was the original from 1995 Raleigh M80 hardtail deteriorated to tatters. I installed Velox fiber reinforced rim tape and new butyl inner tubes on both wheels. Hope for another 8k miles of no flat.
Unrelated to the flat what do you think of the cracks on these 2 year old Fincci tires? Probably has around 1200 to 1500 miles on them. Is it normal? What causes it? Is it unsafe to ride on?
edit: sidewalls look fine with no cracks.
2nd edit:
AI overview
Cracks on bicycle tire rubber typically happen due to aging, environmental exposure, and low inflation pressure.
Tire pressure spec is 45 to 60 psi. I rode it mostly at avg around 30 psi for most of the tire's life for a softer ride (I am light in weight), until recently when I raised it to 45 psi.
Other than the cracks, these tires worked well for me. I ride year round. Not when it rain or snow. I don't go faster than18 to 20 mph. No idea about the tire's rolling resistance. Who cares when I have assistance from a motor? I easily get 50 mile range (on lowest assist level) from my 48V 6 Ah (measured capacity) battery so the tire efficiency can't be that bad.
Rear
front
2nd edit:
AI overview
Rear
front
