BPF317
First off, thanks for reading. I will try and give as much information up front to help with recommendations.
I am 6'5" tall at 235 lbs with a 34.5" inseam. I need a bike that is comfortable with mostly path riding and street commuting in mind (little off road use). I like the idea of a 29ER and have found the below link a good bike to start with
http://www.airbornebicycles.com/products/134-airborne-guardian-29er.aspx
The goal of this build would be a rear hub motor that can provide (all street riding requirements)
1. High top speeds of 25 - 35 mph
2. Ride distances of 15 - 20 miles with some mid grade power
Pedalling will be done little or not at all to achieve the above speeds.
So after spending 3 - 4 hours a night for the past week I have a basic build in mind. This build would be a purchased kit from http://www.conhismotor.com Please let me know what you think. All questions posted at the bottom of my post for easy access.
Main concern is using a 28" rear hub motor on this bike. Is that even possible or should I find a 26" and modify it?
Will I achieve my speed/distance requirements?
I can change or buy my controller/battery/motor somewhere else and not all in the same spot. Do your recommend a specific component or setup?
The BMS drop down had 3 options. I am guessing that it is something of an over clock feature that makes the battery preform or charge better. Is this correct?
Thanks again.
Thanks again.
