sloaaron12
10 µW
Hi guys.
So I just recently got into E-bikes after a friend of mine built his and stumbled onto this forum. I've been reading up the past week and finally feel knowledgeable enough on the subject to start my own build. I'd just like some opinions on my proposed design to see if anyone can point out significant flaws and give some constructive criticism. I'm building this bike as a my main way to get to and from work.
I'm building the bike so that it will be able to cruise at 30 mph (with pedaling), have a top speed of 40mph (also with pedaling), and have a range of 40 miles at cruising speed. For this to be possible I'm considering a rear Cromotor, a 48V 40ah battery (overkill?), and dual suspension. Controller, BMS, and cycle analyst are still up in the air. I'm still finalizing the design and my main concern right now is the integrity of my frame. My proposed design is attached. If its made of steel, will it be able to hold up to the stresses I'm proposing? I'm also concerned about the angle of the front fork. How difficult will that make turning? I'll be riding on two-lane streets so sharp turns won't be too big an issue; I should have plenty of room to turn and doubt U-turns will be necessary.
Any thoughts or suggestions would be appreciated.
Edit: In the sketch, red signifies shock support and yellow is a hinge.
