I have the same controller it can be ordered with or without the waterproof plugs I ordered without but those wires are the same.GordonF said:Help with SVMC 72150 Controller Wiring please.
I recently purchased a controller (NCyclebike, China) but it is wired differently to anything I've seen from Mqcon / Sabvoton. The controller is pre-wired with a "waterproof" loom (for the functions of speed throttle, brake lever switches & TFT display). Fair enough, but separately there is also a male 3-pin connector (black, green, yellow) and a female 3-pin connector (brown, green, yellow). I have asked the vendor repeatedly what these wires are for but they won't or can't tell me (absolutely shocking, but I've reached a dead-end..!).
I'm told that the connectors should be separated for normal running, but joined for programming.
Does anyone know how those connectors correspond to the SVMC standard wiring diagram...?
Those wires are for the Bluetooth programming when running the TFT color display. You must disconnect them to use the Bluetooth programmer and reconnect them when you go back to using the TFT color display.
Attached a picture and number diagram with the corresponding connectors
