spinningmagnets
100 TW
Stieber CSK35PP sprag clutch with a support bearing
This is STRONG AND STEALTH.
No ENO clicking.
The PAS magnets are a sweet added dessert, but...the steak in this entree is awesome. Well done! Thanks for posting.
No ENO clicking.
Some parts I purchased, some of them I had made to my specification acc. to 3D design.amberwolf said:Is this a crankset you made yourself? Or purchased somewhere else?
Thanks spinningmagnets, glad you like my spinning magnets :lol:spinningmagnets said:The PAS magnets are a sweet added dessert, but...the steak in this entree is awesome. Well done! Thanks for posting.
That's top bananas, that is. Very, very, nice work. I assume in this picture, the milled cutout is for the key? If so, I think that's the bit I'd be worried about breaking.bh4801 said:Some parts I purchased, some of them I had made to my specification acc. to 3D design.amberwolf said:Is this a crankset you made yourself? Or purchased somewhere else?
The shopping list comprised the Shimano FC-M815-2 crankset, 2 x 38T 104mm BCD 5mm thick DH chainrings, a set of 4 15mm long MORTOP DH chainring bolts, Stieber CSK35PP sprag clutch, stainless 61811.2RS bearing, 2 keyways, 18 x 4mm dia. neodymium magnets, some 7075 aluminum bar stock.
I had the following work done in a mill/lathe shop:
- lathed the spider off the crankset
- lathed a groove for the seal in the crank arm
- milled a groove for the keyway to the crankset
- lathed an adapter to hold together the clutch, bearing, magnets and keyway on the crankset
- CNCd the chainring adapter to hold the 2 chainrings and a keyway
- CNCd the flange between the clutch and the red seal.
Thankssimon.s said:That's top bananas, that is. Very, very, nice work. I assume in this picture, the milled cutout is for the key? If so, I think that's the bit I'd be worried about breaking.
Please, don't consider my previous comment in any way a criticism. As you say, only time will tell, and if you've managed 1100km so far on it, it's doing pretty well.bh4801 said:lease remember, the crank is PRESSED into the clutch, the beefy inner race of the clutch tightly clamps the crankarm, key and groove.simon.s said:That's top bananas, that is. Very, very, nice work. I assume in this picture, the milled cutout is for the key? If so, I think that's the bit I'd be worried about breaking.
Absolutely notsimon.s said:Please, don't consider my previous comment in any way a criticism. As you say, only time will tell, and if you've managed 1100km so far on it, it's doing pretty well.
Your understanding is absolutely correctsimon.s said:I'm interested in your construction, by the way. My understanding is that you have the crankset with a 35mm OD carrier mounted to it, that carrier having a keyway and carrying the PAS magnet ring, right? The sprag clutch and support bearing are then mounted to that carrier, and the key that holds the sprag clutch runs a dual duty, also keying the carrier to the crankset, via the milled slot in the remaining nub of crankset we see in the photo. Then the new spider and rings mount direct to the outside of the sprag clutch, again held with a key. Is that right?
OK. I'd probably have solved the problem differently, the slightest play in the keyway and it *will* get all chewed up by the key, especially if the carrier, like the nub of remaining crankset, is aluminium.bh4801 said:Your understanding is absolutely correct
No ENO clicking.
The Stieber CSK35PP is rated at 175 Nm nominal, twice that max.
At 170 mm crank length, the crankset is strong enough for a 100 kg / 220 lbs rider STOMPING on his pedals![]()
Unlike cycloid gearboxes, my drive unit is vibration-free (belt primary and planetary secondary), therefore I believe in my construction the the key is sufficiently immobilised in all three axes:simon.s said:...the slightest play in the keyway and it *will* get all chewed up by the key...
Not sure I understand, are you suggesting a choice between right crank arm separating from axle versus losing the ability to drive the bike with pedals?simon.s said:That said, the failure mode for that is probably be due to a stress riser at the end of the shrink-fitted collar, i.e. breaking the crankset right half in two, vs a failure to transmit torque with your setup.
Good 'ol cranky cheeky Chalo, thanks for chiming in :lol:Chalo said:That's cool. Maybe one day you can make a full scale version for adult riders. :wink:
The crank axle's steel. Of course. I R An Idjit.bh4801 said:2. between the steel clutch keyway and steel crank axle along its "height"
Nah, I was suggesting that a stress riser failure mode of a shrink fit on a presumed aluminium axle certainly wasn't a good choice compared to a potential failure mode of "chewed up keyway buggers up pedalling". Hence the suggestion of a looser fit and loctitebh4801 said:Not sure I understand, are you suggesting a choice between right crank arm separating from axle versus losing the ability to drive the bike with pedals?
I couldn't be happier with your reply, thanks a million! 8)simon.s said:...Like I said, that's some really nice work you've done there.
bh4801 said:Now, is there anyone out there to take on Chalo's challenge of fitting a CSK40 to the FC-M815?
That is to boost rider weight rating to some 150+ kgs or DH Elites stomping on their pedals...
simon.s said:bh4801 said:Now, is there anyone out there to take on Chalo's challenge of fitting a CSK40 to the FC-M815?
Given that the CSK series are already bearing supported, you could probably drop the additional support bearing and just run a CSK40 as-is, no?
This has been discussed here: https://endless-sphere.com/forums/viewtopic.php?f=28&t=47618&p=850836&hilit=csk35+failure#p850836liveforphysics said:I don't think it hurts at all to pamper a sprague clutch with bearing support. They are very reliant on the inner and outer cylinder wall geometry staying very flat and round to function.
boostjuice said:Re: Strong freewheeling crankset
Postby boostjuice » 05 Feb 2014, 03:16
...The CSK40 has a healthy margin of 'headroom' when used in freewheel crank duties...
...It is possible that a CSK35 would be strong enough when supported with an additional parallel bearing (and thus if elation had included this in their design avoided all of the premature failures that plagued their custom cranksets), but for only a 170g weight saving over the CSK40, I didn't want to risk it.
bh4801 said:A word of caution: the FC-M815 fits an 83 mm BB.
My FSR is 73mm BB and the axle length protruding to the left is just enough to correctly fit the left crank arm.
In my setup, the polished axle races fit nicely with BB bearings on both sides - if anyone dared CSK40 with a support bearing, they would quickly find out, the polished axle races will be misaligned relative to the BB cups, therefore BB bearings would run in unpolished, lathed sections of the axle or there would be too little axle protruding to the left to allow left crank arm to be safety fitted.
Is that a problem?
I never tested.
