Samd
18650 GA cells?
Kepler said:I am looking at my options in relation to a smaller more compact pack.
Kepler said:I know where you are coming from but the geometry of this bike with drops really bends you over. Makes for an uncomfortable commuter. The Flat bar setup makes the most practical sense with this bike.
With regards to the Microshift shifters for drop bars, I did look at this. Unfortunately they do not have hidden cables and as such make the bike look very 90's. 5800 series 105's are about the cheapest you can buy with hidden cables but then you are forced to go 11 speed. Costs quickly add up. I am using a 9 speed on this bike which is all it needs with the assist setup. With Microshift rapid fire shifters on flat bars, this has really helped keep cost down.
Total agree that drop bars look the goods but i think the flat bar setup isn't too bad either.
You can find 10 speed all over the place with hidden cables. I run Sram Apex on my roadie, and it is dirt cheap, and 10-speed.Kepler said:5800 series 105's are about the cheapest you can buy with hidden cables but then you are forced to go 11 speed.
Mikebergy said:You can find 10 speed all over the place with hidden cables. I run Sram Apex on my roadie, and it is dirt cheap, and 10-speed.Kepler said:5800 series 105's are about the cheapest you can buy with hidden cables but then you are forced to go 11 speed.
Raged said:Mikebergy said:You can find 10 speed all over the place with hidden cables. I run Sram Apex on my roadie, and it is dirt cheap, and 10-speed.Kepler said:5800 series 105's are about the cheapest you can buy with hidden cables but then you are forced to go 11 speed.
I believe all their 10-speed stuff is indexed the same, but I've not needed to worry about it, as the Apex long cage is dirt cheap and supports up to an 11-32 cassette, which is plenty of range for just about anything.
Does SRAM shift indexing work across both disciplines? Eg. SRAM 10 speed STI road shifter with mtb rear derailleur and MTB cassette for bigger gear spread?
I believe all their 10-speed stuff is indexed the same, but I've not needed to worry about it, as the Apex long cage is dirt cheap and supports up to an 11-32 road cassette, which is plenty of range for just about anything.Raged said:Does SRAM shift indexing work across both disciplines? Eg. SRAM 10 speed STI road shifter with mtb rear derailleur and MTB cassette for bigger gear spread?
ScooterMan101 said:Kepler,
I want to go to a drop bar on my e-road bike , I presently have a straight MTB Carbon bar, with Flat Bar Road Shifters,
and it works fine with a thumb throttle , However My hands /palms get sore from just having one position.
( I already have a Specialized Stem that have different + / - Rises with inserts , the comp 17 degree Multi Stem )
so I can be comfortable .
I have sitting in a box, a Drop Bar, and Rival 10 speed Shifter/B. Levers , because, I know of ... No available
throttle that would work with a Drop Bar .
I tried to test a thumb throttle sitting it sideways on the drop bar but it would not work , too unnatural position with the thumb, and also because I also made the thumb throttle with no spring, ( I took it out of the housing , so that I can use it in cruise control mode. and it works great that way, not spring to make my thumb sore !
Hopefully you can design a Throttle, that is small enough to fit onto the brake lever , picture a vertical left and right click mouse pad that we have on our laptop computers.
make it small enough to be glued onto either the right or left brake lever ( road bike STI ) , with more speed in the up position, and lower speed on the lower position,
that way when you grab/pull in the mid to lower part of the Road Bike Brake Lever, you are also backing off the throttle .
Add to that for each click of the up or down button/pad, you increase or decrease the speed 1 kph, that way you can also have a cruise control. then when you need to slow down, you
are simultaneously slowing the bike down because the minus pad is in the lower position , and braking to cancel the cruise control. This would be done with your lower 2-4 finger , while speeding up will be
done using your first finger on the upper plus pad.
Hope I described this well enough .
