mrbill
A friend of mine is planning to convert one of his short wheelbase recumbents into an ebike for commuting.
He wants to be able to keep up with traffic on a city boulevard, so he figures that a top speed of 30-35 mph would be good. When he's feeling energetic he may occasionally take a hillier commute, so he wants a system that won't get too bogged down on hills up to about 12-15% grade. If he rides in the hills he will be pedaling significantly. He weighs about 140 lbs (64kg), so I'm aiming for a total system weight of around 220 lbs (100kg). The commute distance is 22 flat miles round-trip or 37 hilly miles round-trip. If this project goes well, he may wish to ride longer tours on this bike.
The proposed bike is an HP Velotechnik SpeedMachine: http://www.hpvelotechnik.com/produkte/spm/index_e.html
with the added rack (58lb capacity) so that batteries can be carried.
He wants to keep the conversion simple, to retain the original 27speed XT drivetrain. To that end I have recommended the following:
Infineon controller that supports regenerative braking, possibly adding cruise control and ebrakes
Nine Continents 2805, front hub, with disk rotor mount, possible addition of torque arm(s)
Ping 48v/20Ah (or 2x 10Ah) battery
Questions:
1) Is this a good design? If not, what are the problems and possible solutions?
2) Are there other direct-drive front hub motors I should consider?
Thanks.
Questions:
Thanks.
