bbushwacker
100 µW
- Joined
- Dec 8, 2008
- Messages
- 9
Hey everyone,
I have been browsing this forum lots and was happy to find advice on real-life issues.
Mine were completely homemade, and I was told that I was compensating subconsciously not having a motorbike (which is a wild speculation without evidence).
I had to have a solid fully (own a fast non-e commuter) as multipurpose for BC trails/commuting etc. and the budget was limited -- thanks to Gord and bikerescue, I bought an affordable specialised SX frame (04) with springs. It had to be this frame, seriously.
Trouble began, as pure DH the frame came with no rim-brakes. I did not want to go with single brake (off-road+trails, weight!). No big deal, ebikes have this front-disc ezee. This is a bomber jr fork, 20mm through. Adapters from 12-20mm are fairly easy to machine (found a workshop) and the crucial torque-limiter was supposed to go through the fork dropout.
Reality check with ebikes. Axle is too short, will allow only 5mm on each side for washers/nuts. Thought that was nuts and considered giving it a try, but fortunately they seem to have just the right stuff around, so I got a rear ezee, with disc and flywheel (fits in perfectly) kinda-prototype from them. (Heaps of thanks!)
Assembly was straightforward, discs were made to fit and it rolls! Now I need to solve where to put the battery (48V/NiCd 8Ah, pretty darn heavy~10kg). Thought about the top beam of the frame or, below held in place by two under-frame bottle-holder screws and some straps. Any suggestions, there?
Anyways, big thanks to ebike, Justin and his awesome team and bikerescue (Gord's team). The entire process took five weeks and it appears to have worked out! The knobby tires produce quite some drag, but with some pedaling biking in Broadway traffic was a breeze.
Cheers everyone and thanks for the stuff on the forum.
