I have an EVG 36V bike, and the stopping power is amazing. I was going to build a full suspension bike, but after getting LiPo's in this one, I am impressed enough with the stability and braking power that I may just just put a 5304 motor in front to get up to my 40mph top speed goal. The 36V Heinzmann is real torqy at low speeds, and will pull me up my drive all by itself, which is quit steep. If I then have a crystalyte for the higher speeds as a front drive, I would have the best of both worlds...except for the added weight.
Anyway, before I go to the 5304, I wanted to see how much I could get out of the Heinzmann. On 12s2p LiPo, it has quite a bit of power and brings it up to speeds of 22mph on the flats.. which is pretty good. I was warned not to put too much power through that little stock EVG controller, so I was wondering if I could bypass the EVG controller at full throttle with a relay that connects the batteries to the motor directly. This, in theory, would take the heat off the EVG controller, which would then only be used for slower speeds and starting off, and I could see what the heinzmann could do at full power. Of course, I would like to integrate the thermal cuttoff switch, but I would like to get your input.
