G510/M620 52V Firmware
AustroMax
New here
Austria
Hello all,
i finally got my M620 kit 52v 1000W, assembled everything and of course got an issue then. The DP C18 display always shows error 30 a few seconds after turnon, so i replugged and checked every cable and connector several times. Throttle is working, Battery voltage shown, walk mode seems to work and the programming cable works flawlessly through display connector. So i guess its either a problem with the DP18 or the firmware ? Also the Openbafangtool shows low voltage and nominal voltage values fitting to 48v battery, not the 52v version.
Bafang support of course does not help so i hope someone has a 52V Uart firmware i could try out before ordering a new display just for testing ?
SN : CRR10M.1000.SN.U1.5
Greets, Max
