I've read it was popular for tractor pulls!PedalingBiped said:Switch out the SLA with lipo and go drag racing!!
After only about an hour sitting it's up to 2.417!br549 said:It's from 1981 vintage. It was low on water when I first checked it. After filling it took almost 1 gallon of distilled water! It did measure 0 volts at first. After putting water in it it went up to 1.981v.
Actually that sounds like a good idea. The guy I was talking with worked with a lot of old tractor batteries. He said sometimes he would charge them at 40 amps and really get the water boiling. He'd put a 5 gallon plastic pale over them in case they exploded!amberwolf said:I don't know if it will help, but I have also been told by a guy I met that saves old car batteries for storing power for his house that if they were dry, then after filling you could vibrate them or slosh them overnight to help get everything properly "mixed"; I'm not sure how valid that is but it sounds good.He said that he uses an old vibrating chair massager to do it.
It does? That seems like it would be wierd. I'd expect it to just use a big DC brushed motor, maybe on a belt drive with a variable sheave pulley or something, and run right off the batteries.br549 said:Does anyone know if this can be overvolted to 48v? I'm thinking not because it has to somehow convert the DC to AC for running the mower blades and snow blower motor.
amberwolf said:It does? That seems like it would be wierd. I'd expect it to just use a big DC brushed motor, maybe on a belt drive with a variable sheave pulley or something, and run right off the batteries.br549 said:Does anyone know if this can be overvolted to 48v? I'm thinking not because it has to somehow convert the DC to AC for running the mower blades and snow blower motor.
According to this site:
http://www.mrsharkey.com/electrak.htm
the E-20 ( a bigger version of yours, probably) has a 20HP shunt-wound brushed DC motor.
However, it does appear to use an inverter to power the hydraulics pump, and the accessory outlets--but both of these are run from a separate 12V battery on his E-20. Might be on yours, too. He doesn't say.
He does say that the E12 he has uses a smaller permanent-magnet motor (presumably brushed DC as well), but doenst' mention further details.
br549 said:He said sometimes he would charge them at 40 amps and really get the water boiling. He'd put a 5 gallon plastic pale over them in case they exploded!
Good info.liveforphysics said:br549 said:Does anyone know if this can be overvolted to 48v? I'm thinking not because it has to somehow convert the DC to AC for running the mower blades and snow blower motor.
No it doesn't.
And yes, 48v should be OK. Maybe get some relay coils hot enough to melt, maybe not. Since you're working in 6v batteries, try 42v first.
If you want to have something with good function, I would recomend bringing all those ancient 6v cells to a battery shop that will recycle them, and buy new batteries. These monster lead batteries are surprisingly cheap, and that size is extremely common for forklifts.
