kiltedcelt
So, I ditched my hub motor and installed a BBSHD on my bakfiets cargo bike a couple weeks back. I have over 80 miles on the odometer now and the battery gauge on the C965 display is showing no indication of going down - like the battery is barely even tapped out. The display has those bars that equate roughly to percentages of battery power left. For perspective, the battery is a 48v em3ev triangle pack made with 33g Samsung cells and is 28.3 amp hours capacity. Now, with my Mac geared hub motor (and Cycle Analyst) on a Yuba I used to have I did get 100 miles range out of this battery with no indication then that the battery was anywhere near the low voltage cutoff, although the very limited CA battery icon was down on it's last bar. And, for the record, everything else is programmed correctly on the display. The rear wheel is sized correctly (it's 26"), and when I'm riding I'm using pedal assist all the time (almost NEVER touch the throttle), and though there are I think, 9 levels of assist, I'm never really going above Level 4, or a couple times with some major headwinds I went up to I think 6 or 7 briefly. I'm just surprised and a little perplexed that there are 80 miles on the system so far with no appreciable loss in battery level. I read that the BBSHD was an efficient motor, but unless this is a display error it's kind of amazing. I could have the potential of having a couple hundred miles of range with this setup.
