I haven't posted her in a long time. You guys were very helpful the last time I had problems and I am hoping you can help me again. I have an old Gio PB 710 scooter. It has stopped working. I am pretty sure it's a short or bad wire somewhere. Previous owner had done a lot of rewiring and not a great job at it. I bought a testing tool to test the controller, throttle and motor. I am able to test the motor and that works. I am able to test the throttle sort of, there are 4 wire that connect to the controller for throttle, I know it only needs 3 and I tested those 3...they work...I can't get the controller to work with the testing tool. The 5volt light is lit so I know that works but when I plug the throttle into the controller, battery into controller and controller into testing tool...nothing... I have 2 controllers and both same...I am pretty sure they both aren't broken. What I am wondering is what is the 4th wire for in the throttle connection. I really don't want to get down and start following wires under the scooter as like I said the last owner did a crappy job with them and it will be a real pain to do. I am hoping you guys can save me the headache of doing that. Does anyone have wiring diagrams for Gio PB 710 or might know what all the wires are for in the controller for it? Thanks for your help in advance...
