@ snellmin: I'm going to avoid using a left side throttle for now, want to offer eBike kit installation services, gotta stay with midstream, ergonomics. Good to know that option is available, wasn't aware. Thanks!
@ wavezz2k: Tried that with the throttle position, my up-shift lever hits the twist-throttle housing when mounted in what would normally be the ideal position, possibly a different trigger shifter or a thumb index would work better.
Don't laugh too hard, LoL- found the 8spd hub was stuck because underside GNG throttle ring was in the way (even with rotating 'up') - truly, DOH! moment.
Twist shifters, reference 3,7,8, & 9 spd options -
http://www.amazon.com/s/ref=nb_sb_noss_2?url=search-alias%3Daps&field-keywords=SRAM+twist+shift
Prefer to have a reverse throw shifter mounted left side, than a left handed throttle, IMHO.
There are several SRAM twist shifters that can swap out for the push button fire. I found a direct swap out for mine for $10, ordered.
Rather than move throttle to the left gonna move the twist shift to the left (just me, can't do left throttle, too many motorcycle hours).
Plus up, add the three speed Lymen function on a thumb switch on the right. Layout is then 8-spd left twist, 3spd right thumb slide, w/ throttle twist on the right in the correct orientation. Waiting now for 80v Lyen 6FET sensorless, couple more batteries to up -volt...
With Lymen 3 spd, even an old school 3 speed itnernal hub would give a 9 spd type setup. Likely work great.. maybe try to find a old schwinn beach cruiser with a 3 spd, that'd be retro.
