Re: GNG 450 brushless Mid Drive - Primary Drive Modification
by Denisesewa » Fri Jan 18, 2013 12:37 pm
So after realising I posted this in the wrong thread here it is again
Here is a bit more info on the GNG throttles, I have now dissasemble both types that come with the GNG kits, the one with the straight grip has two magnets and the one with the contured grip has a curved linier magnet, after fooling around with both of these I have come to the conclusion that the curved magnet type is junk and can not be modified either physicaly or with resistors to work acceptably at all, the one with the two magnets can be modified in two ways, resistors which seem to " almost" get the job done and by physicaly moving the magnets further apart, it seems the magnets are too powerful, when I seperated the twist parts and held them out just a bit so that the magnets were only half aligned with the hall sensor I could get full articulation with no dead spots . I can also see that the magnets stop having an effect when they get within about 3/16 of an inch of the hall with the throttle closed up properly, as can be seen it the pics it looks as though I can deepen the pocket that the magnet sits in but will have to leave some of the face of the pocket as that surface functions as a throttle stop, I have also come to the conclusion the the stock controller has a narrower input voltage range than an infinion ( lyen ) since I cant make the magura work on the stock controller like I can on the infinion, if I get the motor to crawl and then back off enough to get it to stop the full throttle position maxes out at about 3/4 twist, above that the motor shuts off which indicates the controllers safety feature trips when the controller sees a much lower max voltage than the infinion, on the other end if the resistors are set to optimum so that I get full rpm at full twist the throttle has to have a big dead spot or it will function once but after closing it wont respond again untill resistance is backed off. these two controllers absolutely have different properties with the stock controller having less range of input voltage, I was told this isnt the case mathaticaly or electronicly but the real world results say it is.
On a up note, I have the Magura and Lyen combination working perfectly with 100% articulation and throttle response smooth as a 4 stoke motorcycle, I did this by rotating the pot in throttle assembly and having 2 10k 15 turn cermets in the ground and feed wires, I have found that there is no need to dissasemble the magura to rotate the pot, simply remove the small silver screw and remove the wire retainer, the black screw is what holds the pot in place, once loosened and with the wires free to move the pot can be rotated to any position.
I have invested near 20 hours fooling with these things, I'll report back on the result of moving the magnets in the straight grip throttle.
Picture of straight grip throttle
Picture of curved magnet type on the contured grip throttle
Picture of black screw to loosen to rotate pot on Magura
Picture of 10k 15 turn cermets
